Unifit to be tied: nasty leak from a TOTO
Discussion in 'Toilet Forum discussions' started by Sepp, Mar 11, 2007.
  1. Sepp
    Sepp New Member
    Mar 11, 2007
    First-time poster here. Our TOTO Carrollton has developed an unpleasant leak. I pulled it out this afternoon thinking there might be a problem with the wax flange seal, but I'm pretty sure the problem is on the inlet side of the Unifit adapter. I say that because a) most of the wetness is right up against the wall behind the toilet, and b) the rubber seal which is supposed to be tie-wrapped to the Unifit thing is no longer on the Unifit thing...looks like it came along for the ride when I removed the toilet. I was just wondering whether I can get a replacement rubber seal...or do I have to buy a whole new Unifit adapter?
  2. jadnashua
    I'd call Toto and explain the situation...they'll probably send you what you need.
  4. Sepp
    Sepp New Member
    Mar 11, 2007
    The tie-wrap was the culprit
    [​IMG]
    Actually, the rubber part looks like it will be reusable. I just need a tie-wrap that will stay tied to secure the rubber seal to the unifit adapter. The teeth on the original tie-wrap are microscopic...no wonder it came undone.
    Just an FYI.
Similar Threads: Unifit tied
Toilet Forum discussions Toto Unifit & Water Supply Location Jan 12, 2016
Toilet Forum discussions Problem with Flange Height for install the Toto Unifit Nov 11, 2015
Toilet Forum discussions Other concealed skirt toilets and using the Toto unifit on them May 10, 2015
Toilet Forum discussions Toto Soirée with 13 inch rough in can I squeeze the 14 unifit or stick with the 12 Jan 1, 2015
Toilet Forum discussions leaking toto unifit Aug 28, 2014
