Uneven tile so flange does not sit on top
WaukeshaMike
Waukesha, WI
I recently tiled a basement bathroom... I use floor leveler to level the floor and bury the cable for the radiant heating. The problem - I did not carry this throughout the entire bathroom. This is where the problem starts. My tile is not level on the back side of where the toilet will sit. I am ready to install a 3" inside flange into a 4" stub-out (I believe this is acceptable based on previous threads). When I do this, the SS part of the flange sits on top of the tile in one spot, but is 1/4" above the tile in the back (see picture). My plan is to assure the flange is level, then set the wax ring and toilet into place. I will use plastic shims to level the toilet and then grout the gap between the tile and the toilet to assure stability.
Is this correct? Lesson learned... level the entire floor - so simple.
I'm assuming that you dryfit that, or is it now cemented in place?
The cement literally melts the plastic, so that gives you a little bit of leeway. Note sure, but I think I'd try this: spread the cement on both pieces...let things sit for maybe 30-second, then apply a second coat. That will give a larger quantity of solvent, and might allow it to be able to melt enough to fit down and sit flush on the tile. You may need a heavy weight to hold things down for a bit while things harden up again, otherwise, it may just pop back out on its own. I might try just standing on it for a bit.
Make sure that there's no lip or edge on the flange and that the pipe is cut off properly so that there's no interference.
I'd also wait to see if one of the pros has some thoughts, as you'll only get one chance on this, and I'd not want to be wrong!
