Uneven Closet Bend Help
Discussion in 'Toilet Forum discussions' started by Robert McKenna, Apr 7, 2005.
  1. Robert McKenna
    Robert McKenna New Member
    Apr 7, 2005
    I am installing new toilet and flange to an existing 3" turned-up CI 90 closet bend in a concrete basement floor. The existing closet bend is set uneven (one edge of pipe opening is about 1/8" higher than the other), so that when the new flange is seated squartely on the bend, it is sloped almost 1/4" from actual level edge-to-edge.
    Can this be corrected short of excavating & resetting existing bend & drain line? Specifically, can adjustments be made in the bend to flange connection to bring it level, eg. grind down high end to level? If not, can the uneveness be compensated for at the flange to closet connection, eg. extra thick wax ring?
    Thanks.
  2. hj
    flange
    A plumber could install a new flange with a lead/oakum joint and then "snap" the excess bend off flush with the top. You might not want to try it since you could break the bend.
Similar Threads: Uneven Closet
Toilet Forum discussions Uneven closet flange in concrete Jan 8, 2007
Toilet Forum discussions Uneven tile so flange does not sit on top Dec 19, 2016
Toilet Forum discussions Uneven flange Dec 27, 2015
Toilet Forum discussions Uneven toilet bottom? Feb 21, 2014
Toilet Forum discussions Uneven toilet flange Dec 19, 2013
