undoing Pex pipe fittings
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by drummertom, Apr 13, 2006.
  1. drummertom
    drummertom New Member
    Apr 13, 2006
    :confused: Hi. I just recently bought a motorhome and the PO redid the plumbing with pex pipe. That's all well and good except the water heater is leaking. Is there any way to get the pex fittings loose without destroying them? I don't have the tools to redo the fittings so I am wondering what my options are. Thx for any help!!
    Tom
  2. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    shark bite fittings
    just cut it off above the heater.....
    then use 2 of those shark bite fittings and switch it to copper
    to the water heater
  4. drummertom
    Apr 13, 2006
    OK But!!
    Sorry to sound ignorant but what are sharkbite fittings?
  5. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    http://www.cashacme.com/pdf_sharkbite/spec/SharkBiteWHKitSpec2-3-05.pdf#search='sharkbite%20fittings'
    Probably around $10 a fitting. GOOD LUCK
  6. Cass
    Cass Plumber
    Nov 12, 2005
    Where did that cow go?
Similar Threads: undoing pipe
Plumbing Forum, Professional & DIY Advice Lint will be the undoing of me... Apr 12, 2006
Plumbing Forum, Professional & DIY Advice "Undoing" joint in ABS plumbing stack? Sep 9, 2004
Plumbing Forum, Professional & DIY Advice Supply Line Pipe Type & New Stop Valve Sunday at 1:46 PM
Plumbing Forum, Professional & DIY Advice Sealing pipe through concrete Friday at 11:26 AM
Plumbing Forum, Professional & DIY Advice How do I fix this vent cast iron pipe? Feb 21, 2017
