Understanding Fixture Units
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by bengal21, Dec 30, 2009.
  1. bengal21
    bengal21 New Member
    Dec 28, 2009
    Des Moines
    Hello,
    If someone could answer the following question for me it would be appreciated. And the units I am using are from the UPC.
    If I have a 2" vent that can serve a total of 24 FU can I split the fixtures on opposite sides of the room into 1.5" vents (as long as each side doesn't exceed 8 FU) and tie them together into a 1.5" x 1.5" x 2" tee to run up to connect with the main stack? They would all run vertical until 6" above the flood elevation of the highest fixture.
    Am I correct in summing the FU for each vent branch? i.e.
    Vent one (1.5") has a total of 7 FU and Vent two (1.5") has a total of 5 FU so each vent alone is under the 8 FU for a 1.5" vent. So tying them together for a total of 12 FU in a 2" vent is acceptable because it is under 24 FU?
    Thanks for all of the expert advise received. It is tremendously helpful. :D
  2. hj
    vents
    As a practical matter, I do not think I have EVER seen an inspector count the FU's for vents, and neither do I do it.
  4. Doherty Plumbing
    Doherty Plumbing Journeyman & Gas Fitter
    Jun 22, 2009
    Red Seal Journeyman Plumber & Licensed Gas Fitter
    Penticton, BC
    You are absolutely correct....
  5. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    I count them if I see something that just doesn't look quite right. Usually that would be every fixture in the house vented through an 1 1/2" vent.
  6. Winslow
    Winslow Plumber
    Dec 30, 2005
    Hawaii
    That is OK as long as there isn't a toilet being vented through 1 of the 11/2 vents. Toilets require a 2" vent under the UPC.
  7. hj
    vent
    The question is somewhat simple for a set of local vents, but the subject becomes more complex if he is merging all of these vents into a single roof penetration, because then any code requirement for the main vent comes into play. Does your code require one FULL SIZED vent all the way to the roof? Does it require that the combined AREA of all roof penetrations equal the AREA of the incoming sewer line? There could also be other local requirements.
  8. Winslow
    Winslow Plumber
    Dec 30, 2005
    Hawaii
    The UPC requires the aggregate cross section of the vents to be equal to the cross section of the main sewer. To verify the local requirement would require access to ammendments by the local jurisdiction.
  9. hj
    Upc
    That is the UPC, but the IPC may allow ANY sized penetration or use the diameters of the pipe to determine the quantity and sizes. (The IPC writers were not mathameticians").
Similar Threads: Understanding Fixture
Plumbing Forum, Professional & DIY Advice Triple Stacked bathrooms. Am I close to understanding this.... May 9, 2016
Plumbing Forum, Professional & DIY Advice Understanding gas meter? Nov 3, 2015
Plumbing Forum, Professional & DIY Advice help understanding code - drains Dec 27, 2014
Plumbing Forum, Professional & DIY Advice Understanding Furnace Drain Dec 2, 2014
Plumbing Forum, Professional & DIY Advice Understanding PEX pressure loss Jul 28, 2014
