Mike from Brier
We have a large, deep stainless steel kitchen sink that is under-mounted beneath a granite counter top. If I remember correctly, the counter top installers used some kind of adhesive on the sink flange where it contacts the lower surface of the granite before they mounted the sink several years ago. Our problem is that we keep getting this black gunk building up in the seam between the sink and granite, and no amount of attention keeps it from returning. Last year we had a handyman come in who dug a bunch (if not all) of the gunk out of the seam, and then applied a high quality silicone caulk there to (hopefully) prevent it from reoccurring for a while. He said at the time we might need to do this every couple years, that this type of buildup is very common for an under-mounted sink. Keeping it as dry as possible by wiping the area down after each use was supposed to help, which we've tried to do, but the gunk just keeps building up and it's only been about six months since the "repair".
Is there a product we could install to the seam that might hold up better than the caulk he used without removing the sink in the process? Or would we be better off having the sink dropped and some type of better adhesive installed than the original installers did? And if so, what would you suggest?
By the way, there is zero evidence of water leaking under the sink anywhere, so that hasn't been an issue.
Thanks for any and all ideas!
