Underlayment for vinyl flooring - screw vs nail
Discussion in 'Remodel Forum & Blog' started by akeop, Feb 16, 2005.
  1. akeop
    akeop New Member
    Feb 16, 2005
    Hello,
    In the past when I have put down underlayment before putting down a linoleum bathroom floor, I have used underlayment nails. I am wondering if I can screw the underlayment down instead
    I am my working on the floor in my master bath. I removed the tiles and the concrete/wiremesh substrate beneath it. In order to get it back to an even level with the wood floor in the hallway, I am installing a 23/32" pc of underlayment.
    I did this same thing in another bathroom in the house and it worked fine.
    The reason I am thinking of screwing the underlayment down is that the bathroom is on the second floor, and as part of the remodeling I need to do do work on the drain pipes of the shower. Although everything is working fine with the drain pipes, I like to give myself as easy access as I can.
    If I screw the underlayment on, it would be much easier to gain access to the drain pipes in the future, should that need ever arise.
    I am looking for cons of using screws.
    Thanks,
    Paul
  2. PEW
    PEW DIY Senior Member
    Paul,
    There are several considerations mostly based on your floor covering requirements.
    As long as the screws are flush with the underlayment you should be fine. However, depending on the floor covering you may have to cover the screw tops with a filler. Some floor coverings only use adhesive around the outside, others need the whole floor covered and a super smooth underlayment nailed.
    I screwed an underlayment to the floor of our kitchen remodel one time, remarking to my wife that I pitty the fool that had to take the floor up as I went heavy on the screws. To make a long story short, I was the fool! We changed our minds on the floor covering before the job was done, the new one needed a super smooth underlayment. Still using used screws here and there!
    Good luck,
    Paul
  4. jimbo
    jimbo Plumber
    San Diego, CA
    If you are putting down any type of vinyl, the underlayment must be perfect. If you use nails, they must be countersunk. With screws it is easy to drive just below the surface. In either case, you must spackle the heads.
    With nails, you always have nail-pops to worry about down the line.
  5. akeop
    akeop New Member
    Feb 16, 2005
    Thanks for the replies. With nails, I know I put them every 4-6" based on something I read. Any suggestions for screws based on your experience?
    Paul
  6. jadnashua
    I think you need them at about the same intervals which is one reason many people use nails, cheaper both in labor and materials...my unprofessional opinion. You don't want the floor squeaking - the screws are better at that than nails, too.
  7. Scotty
    Scotty New Member
    Jan 6, 2005
    Handyman
    Chicago Area
    Underlayment for Vinyl Flooring
    Where conditions exist for water damage to happen, I like to use concrete board instead of wood for underlayment. Installed, using the screw pattern you suggested, there won't be the creaks and the level will be more consistant. If tile squares are used, slight separation over time won't occur with humidity variables. Will the house be sold soon or do you anticipate changing it again down the road? Consider the bragging rights or the time you may save or have spent doing whats been done allready. It might take a few shakes longer and be a tad more expensive, but the extra dime will make the dollar spent pay off exponentially in the long run.
Similar Threads: Underlayment vinyl
Remodel Forum & Blog How to remove vinyl underlayment (paper stuff) on concrete bathroom floor? Aug 16, 2008
Remodel Forum & Blog 1/4" underlayment over concrete? Jan 22, 2009
Remodel Forum & Blog Underlayment Sound Protection Oct 12, 2008
Remodel Forum & Blog Underlayment for Tile Floor Aug 14, 2008
Remodel Forum & Blog underlayment under new tub Apr 21, 2008
