undercounter lighting
Discussion in 'Electrical Forum discussion & Blog' started by rockycmt, Jan 22, 2009.
  1. rockycmt
    rockycmt Member
    Nov 13, 2007
    New York Metro Area
    Which is best? Hardwire fluresent or Low voltage
  2. jar546
    jar546 In the Trades
    Feb 20, 2008
    USA
    Depends on if you want to be able to dim them from a single location or dim them at all.
    I install individual xenon with the transformer in each unit that has a hi/lo switch. No dimming.
  4. Scuba_Dave
    Scuba_Dave Extreme DIY Homeowner
    Jan 5, 2009
    Used to be in IT
    South of Boston, MA
    I went with LED
    3 pull around 4w total, 1 transformer can power up to 6 puck lights
    Each puck light has 12 LED's - lots of light - no heat
  5. edlentz
    edlentz New Member
    May 26, 2008
    Michigan
    I got some inline LED strip lights. A 15" with 21 leds (I think) fits perfectly under the cabinet. They are powered by 110, no transformer. Not dimmable but at about 1 watt per strip we can leave them on forever.
  6. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    We used these for years but the price of oil keeps going up and we may go back to dipping strings into wax again.
    [​IMG]
  7. Scuba_Dave
    Jan 5, 2009
    Used to be in IT
    South of Boston, MA
    I still have quite a few of those lamps around :D
  8. CarlH
    CarlH New Member
    Feb 4, 2007
    Northern VA
    Who makes these? Where can I find them?
  9. rockycmt
    rockycmt Member
    Nov 13, 2007
    New York Metro Area
    If I choose to go with low Voltage… What is the best install procedure? I want them switched so should I
    Countertop switch to an outlet on top of cabinets to power a transformer.
  10. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    If you do choose low voltage, none of the wiring can be concealed in the walls. Makes for a tough clean looking install.
  11. drick
    drick In the Trades
    May 16, 2008
    I don't know that this is entirely correct. As long as the wiring is rated for it you can run it in the wall, yes? What if you used 14/2 romex between the xenon fixtures and transformers. Or what if you used 14 gauge in wall speaker wire?
    -rick
  12. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    411.4 Specific Location Requirements.
    (A) Walls, Floors, and Ceilings. Conductors concealed or extended through a wall, floor, or ceiling shall be in accordance with (1) or (2):
    (1) Installed using any of the wiring methods specified in Chapter 3
    (2) Installed using wiring supplied by a listed Class 2 power source and installed in accordance with 725.130
  13. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
    Uh, Mike? They're DIYers. I doubt they have a copy of the NEC kicking around. Could you maybe explain, briefly, what's meant by "Chapter 3", "Class 2 power source", and "725.130"?
  14. Cookie
    Cookie .
    Oct 7, 2005
    It can be found on the internet Frenchie.
  15. Scuba_Dave
    Jan 5, 2009
    Used to be in IT
    South of Boston, MA
    and 725.130 refers you to 8 other code sections :rolleyes:
    Chapter 3 is probably a hundred pages or more
  16. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    Well then why are they installing electrical circuits for if they don't have a copy of the rules?
    I have been doing this for over 40 years and I got to have a copy of the rules to know if it is right or wrong. Are they that much smarter than a old seasoned pro like me?
    I suppose that it would be a lot simpler to just go make the installation for them than to try and teach the NEC on a discussion forum but I will give it a go anyhow.
    Chapter Three of the NEC is titled;
    Chapter 3 Wiring Methods and Materials
    This chapter will contain the rules that apply to the wiring methods of all conductors, cables and raceways.
    The referral to chapter three in 411.4 means that any of the wiring methods out there and approved for branch circuits would be allowed to be used.
    A class 2 circuit is one that is supplied by a class 2 power source and the rules change. They can’t be around circuits that are bigger than they are as they might get hurt. There are about a half dozen conductors listed for the installation of class 2 power limited conductors. Speaker wires are not part of this listing.
    I feel as though I must ask you a couple of questions now.
    Do you really think that someone would undertake installing something that is sure to cause fires and kill without first doing a lot of research on the proper safety issues?
    Surly you don’t think that someone would undertake an electrical installation without first obtaining a copy of the current electrical codes and doing an in-depth study of said codes, do you?
  17. Scuba_Dave
    Jan 5, 2009
    Used to be in IT
    South of Boston, MA
    The whole idea of forums like this is to assist people
    Do I think people should undertake wiring without research?
    NO, but that IS what the person is doing
    Do I think people will undertake wiring without research?
    YES, especially when they receive "assistance" such as yours
    You might as well have said: "The answer is on the internet somewhere, go find it"
    A better answer would be:
    NO, you can't do that see - code such & such
    or
    YES, you can do that as long as you follow code such & such
    AND giving them a link to look up the code, like this:
    http://nfpaweb3.gvpi.net/rrserver/browser?title=/NFPASTD/7008SB
    That is how people learn
    Otherwise they will just ignore code & do what they want
    Which is what everyone does NOT want, including the person looking for help
  18. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    I understand that you have no way of knowing but I have been dealing with Frenchie for about as many years as you have been walking and the post was really meant as a joke that only me and Frenchie would understand.
    But I do thank you for responding.
  19. Scuba_Dave
    Jan 5, 2009
    Used to be in IT
    South of Boston, MA
    Ah, I see.....so you are over 65 then I guess & just about retired
    I'm close to 50 :)
  20. Cookie
    Cookie .
    Oct 7, 2005
    Well, when I said it was on the net, I said it, because it really is. I looked it up. So, the poster would be able to check it out, too, and see for himself what the classes and codes are, not all that difficult to do. Or even read. They are capable of doing that.
  21. edlentz
    edlentz New Member
    May 26, 2008
    Michigan
Similar Threads: undercounter lighting
Electrical Forum discussion & Blog Vanity Lighting Issue Jan 7, 2017
Electrical Forum discussion & Blog Ceiling Fan & LED Lighting Sep 1, 2016
Electrical Forum discussion & Blog Future Size of Recessed Lighting Cans? Apr 21, 2016
Electrical Forum discussion & Blog Recommendations for LED Landscape lighting for 30 foot palm trees Jun 17, 2015
Electrical Forum discussion & Blog Recessed Lighting Options for Kitchen Jan 14, 2015
