Under Slab C.Iron to Plastic Couplers
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by tsawicki, Sep 13, 2004.
  1. tsawicki
    tsawicki New Member
    Sep 13, 2004
    Seattle, WA
    I need to connect a plastic pipe to my cast iron main drain line under the basement slab.
    I have read about mission couplers and looking at the Fernco website wonder if these are the couplers referred to here and elsewhere:
    http://www.fernco.com/NH.html
    Description from the website:
    AISI 304 Stainless Steel Shield
    AISI Stainless Steel Clamps and Screw Housing:
    Full size 9/16" wide bands and one piece screw housings are mechanically interlocked for strength. The wide clamp band provides enhanced sealing force.
    Specially Beaded Gasket:
    Unique beaded Neoprene gasket grips with superior holding and sealing power. Gasket conforms to ASTM C 564.
    HD-4000 Couplings:
    meet ASTM C 1277 and meet test criteria of CISPI 310.
    Thanks for any help,
    Todd
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    Most areas just the rubber ferncos without the band is code but you can install shielded no hub mission couplings underground.
Similar Threads: Under Slab
Plumbing Forum, Professional & DIY Advice Small leak under slab Jan 6, 2017
Plumbing Forum, Professional & DIY Advice Under slab new plumbing help - venting/santee Aug 1, 2016
Plumbing Forum, Professional & DIY Advice Abandoning cast Iron plumbing under slab Jul 18, 2016
Plumbing Forum, Professional & DIY Advice Back to back restroom under slab drainage Jul 17, 2016
Plumbing Forum, Professional & DIY Advice Underslab leak Jun 23, 2016
