Unconventional Shower Arm Thread
Jarv3yy
California
Hey. I'm trying to remove my shower head arm to replace it with a S arm. I have tried channel locks wih no luck. Then chipped out what pipe dope I could using a utility knife and used penetrating oil an still no luck. Any ideas of what else I can do? I'm afraid if I cut the pipe and it won't come out still I will be screwed. I included some pics of the problem.
Thanks for any help.
Vegas_sparky
Digital Billy
LV,NV/ Nowhere,UT
Is the threaded portion in the pic part of the shower arm, or a fitting?
I'd keep twisting on it harder. A better pipe wrench will get a better bite, and give you more leverage. Cut it and use an extractor if that fails. One of the pros would know better.
With all those marks on the shower arm, I don't know. I've never seen one installed that way, or that hard to spin out.
You may need to go into the wall on that one.
I suspect that the 3/4" thread, if that is what it is, will come loose before the shower arm does. And not sure how they got the two pieces connected together.
QuasiPlumber
California
Was hoping to find a little more info here. I have a similar looking situation. Cannot remove the arm.
How is this configured? All one piece? Anyone have any more info on these types of configurations?
Thanks
Marlinman
Jacksonville Florida
These are typically used on fiberglass or plastic shower walls. Leaving the front locknut on and as tight as possible use 2 opposing pipe wrenches to unthread.
