Unclip handle hose for moen single?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by tfcallahan1, Dec 25, 2008.
  1. tfcallahan1
    tfcallahan1 New Member
    Dec 25, 2008
    Hi,
    I have a moen single handled faucet and need to unhook the line that feeds the hand held part (that the water comes out of) from the main faucet assembly.
    The installation instructions show that there are two clip like things on an intermediate piece that connect the metal hose from the handheld to the faucet base. The instructions show that you can use your hands to close these clips when installing.
    Do I just need to pry these open somehow to disconnect the hose? I don't want to damage anything.
    Thanks in advance for any help!
    Tim
  2. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    Is this a kitchen sink faucet?
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I know the ones you are talking about...
    Tell you the truth I have installed them but never removed one yet.
    I guess I better look the next one I install over real close to see how they come back apart.:confused:
    You might want to give Moen a call 1-800-BUY-MOEN
  5. hj
    clip
    The clip usually has a provision on the other side from the one you pushed to close it that you push to release it. If not, then pry it out.
  6. tfcallahan1
    Dec 25, 2008
    Successfully Removed
    Thanks everyone for the reply. It is a kitchen faucet.
    There was a white plastic clip that had a flat side and two flange like things that go through either side of a barrell shaped piece that slides over the pipe from the faucet base.
    Pushing the flat side causes the flanges to snap around the pipe holding the barrell shaped piece in place.
    I pushed out the flanges with my fingers and it unsnapped.
    Thanks for the direction!
    Tim
  7. tfcallahan1
    Dec 25, 2008
    Clarification
    Just wanted to clarify the above.
    The bits I described as "flanges" are more like tangs that go on either side of the barrel into which the end of the hose fits.
    The tangs are part of a U-shaped piece of plastic, the bottom of the U is flat and, when pushed, causes the tangs to snap over the barrel and hold in the hose.
    To remove, I pressed the tangs apart e.g. widening the U - and they slid back out from over the barrel, freeing the hose.
Similar Threads: Unclip handle
Plumbing Forum, Professional & DIY Advice Moen Single Handle Pull Down Kitchen Faucet water supply hose question 39 minutes ago
Plumbing Forum, Professional & DIY Advice How many plumbing fixtures can 3/4" supply handle Feb 10, 2017
Plumbing Forum, Professional & DIY Advice Faucet Handle Removal & Leak Repair Feb 8, 2017
Plumbing Forum, Professional & DIY Advice Replacement Handle for American Standard Tub/Shower Jan 17, 2017
Plumbing Forum, Professional & DIY Advice Water hammer after servicing a pressure balancing single handle shower valve Nov 15, 2016
