Ultramax vs. Ultramax II
Steve565
California
Doing a remodel in California and must use 1.28. We had great luck in our last house with the Ultramax CEFIONTECT, what is the difference between the Ultramax and the Ultramax II ? Thanks !!
The 854 Ultramax has a straight down the bowl rinse.
That standard height is 14-5/8" and the "L" ADA version is 16-1/2".
L= 16-1/2"
CEFIONTECT is an option on them. CeFiONtect ceramic glaze
The 604 Ultrmax II has two outlets at the top of the bowl and the two streams of water swirl around the bowl.
The bowl height is 16-18" before the seat is added.
F = 16-1/8" height.
CEFIONTECT is standard with the whites. CeFiONtect ceramic glaze
Thanks, which do you think operates better ?
I prefer the Ultramax II if you like the taller bowl.
I also have the standard height Ultramax in the downstairs. Most of the parts are the same, the trapway design is the same.
It may depend on the look you prefer too.
The II toilets rinse the sides of the bowl better and are a bit easier to clean because there is not conventional underside of the rim.
