Ultramax toilet keeps running
Discussion in 'Toilet Forum discussions' started by Bob M, Nov 22, 2004.
  1. Bob M
    Bob M New Member
    Nov 22, 2004
    I'm sure you've had this question before but when I did a search I couldn't find it.
    I have a Toto Ultramax with the G-max flushing system. It is at a pooint where it keeps running - water fills the tank, past the overflow hole and doesn't stop. Any suggestions?
  2. It sounds like one of two problems -- neither of which is severe. First, check to make sure the flapper in the tank is closing completely after the flush and seating properly against the opening of the flush valve at the bottom center of the tank. If that's not the problem, then you should replace the fill valve in the tank. The Ultramax is equipped new with a fill valve made by Korky and I'm told they are readily available in hardware stores. If you can't find the Korky, you can use a Fluidmaster. They're inexpensive and easy to install. Just follow the directions that come with it.
  4. jadnashua
    You could have gotten some sand or junk in the seal valve. Not sure on the Korky, but that part is probably replaceable. It may be just take it out and clean it off. On a Fluidmaster, it is about a 30-second operation, not sure on the Korky. A whole new valve is pretty cheap, so either way may work. If this is the first time you plumbed it up, it could be that the valve water height was incorrectly adjusted, too. Again, I'm not familiar with how to do that on a Korky, on a Fluidmaster, you twist the float like a screw, and it adjusts up and down. The Korky doesn't look like it works that way, I just don't know.
  5. Terry
    Aug 17, 2004
    [​IMG]
    The fill valve is made by Korky.
    Repairs are simple. Instructions are here.
    One of the local big box stores here carries the assembly cap and the Korky fill valve. I know I carry them on my trucks.
Similar Threads: Ultramax toilet
Toilet Forum discussions TOTO Ultramax One Piece Elongated ADA Toilet slow leak Oct 29, 2016
Toilet Forum discussions Need 3 new toilets: Toto Ultramax II or American Standard options Feb 20, 2015
Toilet Forum discussions Any thoughts on the 1.0 GPF TOTO toilets (Drake II and Ultramax II)? Jan 20, 2015
Toilet Forum discussions Terry: I need to buy 3 replacement toilets, which Toto? Drake,Ultramax, Ultramax II? Jan 4, 2015
Toilet Forum discussions TOTO Ultramax CST 854 Toilet Pulses once or twice after it fills Jan 23, 2014
