Ultramax and 11" Rough in
Discussion in 'Toilet Forum discussions' started by MrBrindAmour, May 16, 2007.
  1. MrBrindAmour
    MrBrindAmour New Member
    May 12, 2005
    Alberta
    I searched the forums for this particular problem and didn't see this exact issue:
    I was just about to install a Toto Ultramax and I measured from the wall to the centre of the mounting bolts on the existing toilet. THe distance is 11 inches.
    The Ultramax spec sheet indicates a 12 inch rough in (measured from the wall to cetre of mounting bolts). Does this preclude me from getting an Ultramax?
    Alternatively, if I go to the Soiree or Carlyle they appear to have an adjustable distance from 10 inches to 14 inches - would that make the install easier?
    Any help would be appreciated - thanks in advance.
  2. jadnashua
    Most toilets have a space behind them to the wall. Each one is different. 11" is probably too close, but you should be able to find the spec sheet on the Toto website. I think, but don't quote me, that that model normally has 0.75" behind it on a normal 12" rough, so you are 1/4" short. Sometimes there is enough slop where you can gain that, sometimes you can't.
  4. Terry
    Aug 17, 2004
    The specs allow for aprox 1" behind when set at 12"
    That means that 11" should work. I've set them at 11" before.
    You can also move the closet bolts out 1/4"
    The Soiree and the Carlyle with the 10" Unift could even be installed with 9.25"
  5. MrBrindAmour
    May 12, 2005
    Alberta
    Thanks for the comments. I got the Ultramax and did a dry-fit and it fits with a 1/4" to spare.
Similar Threads: Ultramax Rough
Toilet Forum discussions TOTO Ultramax II rough in distance Jan 31, 2017
Toilet Forum discussions Toto Ultramax 12" rough-in, but sits 2" out from the wall Oct 24, 2010
Toilet Forum discussions Install Toto Ultramax on 14" rough-in.. Nov 9, 2009
Toilet Forum discussions Will Ultramax fit 11 1/2" rough in? Jul 21, 2008
Toilet Forum discussions Ultramax impossible with 11.5" rough-in? Jan 6, 2008
