UF instead of submersible well pump cable?
Qwertyjjj
Can you use UF submersed in a deep well to connect to a pump if it's wired into a GFCI?
It seems to be very hard to find submersible wire where I am.
Is there any difference in the wire that makes it especially suited for submersible applications?
Craigpump
It will conduct the power, but it's a PIA to work with.
Tie wraps do not properly secure wire to pipe that hangs in a well. I've seen wire ties settle so there is nothing supporting the weight of the wire, then the wire drags on the wall of the well which chafes off the insulation.
I've never seen a submersible pump wired into a GFCI.
Qwertyjjj
So, what do you secure the wire with? Scotch tape will just come undone in the water?
It's 115V so I want to connect it to a GFCI mounted on a nearby lamppost - especially as it's just for irrigation and all outside receptacles have to be GFCI. The proper 220V well pump we have is wired into the panel.
Jadziedzic
Active Member
New Hampshire
You should be using stranded conductors in this application as they can better accommodate any vibration/flexing imparted to the cable by the pump. I've not seen UF cable with stranded conductors.
Qwertyjjj
Also, do you use brass clamps to attach the polypipe to the pump brass connector underwater? Cannot seem to find brass collar clamps much.
Craigpump
Because...brass clamps would not have the strength or integrity. If the water has a low pH, the acids would eat up the brass quickly. If you're installing a pump with a stainless discharge head, you want to use a stainless insert x male adapter. Dissimilar metals don't get along well under water.
Qwertyjjj
And if you install a pump with a brass head?
Then you add stainless clamps, which rust? :confused:
Most of the stores seem to sell only brass adapters for the 1" polypipe to attach to.
Craigpump
Good quality stainless clamps don't rust or fall apart. In addition, they are insulated from the brass by the poly pipe.
Dissimilar metals don't get along. When brass and stainless are combined, most of the time the brass will fail.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
Brass barb fittings are fine with a brass pump head, extra length for two clamps is better. Even with good Stainless Steel clamps I would tape over them with electric tape to seal them as best I could.
