type of p-trap for tub drain
Discussion in 'Shower & Bathtub Forum & Blog' started by Brian Guinness, Jul 8, 2013.
  1. Brian Guinness
    Brian Guinness New Member
    Jul 8, 2013
    Maryland
    Hi all,
    (apologies if this has been asked an answered, but i searched quite a bit)
    I'm in the midst of a bathroom remodel and am working on replacing the tub. I removed the old tub and the brass drain assembly, which connected to 1 1/2" PVC. I'm looking to put in an all-PVC drain assembly. Because of the way the drain pipe is angled, a p-trap with union joint (and union nut) is dry fitting much better than a p-trap that uses PVC cement to connect the two pieces - which was my first preference as I was more confident that it would never leak. But this cemented p-trap assembles top-to-bottom almost 1" higher and really throws everything off when connected to the drain pipe.
    So... is it OK and proper to use a p-trap with a union joint for a tub drain that i will have almost no access to once i drop the tub in? I'm a bit worried about the possibility of a leak, but am hoping that's just paranoia
    thanks!
    Brian
  2. Terry
    Aug 17, 2004
    Plumbing inspectors like to see a solvent weld p-trap.
    In forty years, I've never installed a p-trap for a tub or shower that had a union.
  4. Brian Guinness
    Jul 8, 2013
    Maryland
    Thank you, Terry, for the quick reply. It is what I expected. Now I just need to figure out how to get a solvent weld p-trap to fit!
Similar Threads: type p-trap
Shower & Bathtub Forum & Blog Remodel: what type of drain to use in shower receptor Jan 12, 2017
Shower & Bathtub Forum & Blog Best type of shower mixing valve / highrise bldg with poor pressure balance Dec 21, 2016
Shower & Bathtub Forum & Blog Just installed acrylic Delta Tub and 3 piece surround (attach to studs type) Dec 11, 2016
Shower & Bathtub Forum & Blog Leaking valve in shower - Have you seen this type of valve before? Nov 8, 2014
Shower & Bathtub Forum & Blog What type of repair options available for tub coat peeling? May 22, 2014
