Two wires
Discussion in 'Electrical Forum discussion & Blog' started by jc60618, Sep 21, 2010.
  1. jc60618
    jc60618 DIY Junior Member
    Dec 12, 2009
    Apprentice Plumber
    Chicago
    I am replacing a ceiling fan, when I removed it I noticed no grounding wire just two wires which are the same color. Is there a way to find out which is the positive/hot wire?
  2. jimbo
    jimbo Plumber
    There should be a ground wire. Anyway, of the two internal leads, one should be "identified" meaning a white stripe, or ribs on it , or something. That is the neutral wire.
  4. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    If there is no ID on the wires from the box, run an incand. bulb from each wire, in turn, to a "known good ground". The hot wire will light the bulb.
    A meter may respond to Phantom Voltages and confuse you, unless you are using a type of rugged, solenoid voltmeter that electricians use that is called a Wiggy.
  5. Ian Gills
    Jul 24, 2007
    USA
    Ah, the joys of 1950s wiring. All wires turn to black.
  6. hj
    There are many ways for US to determine which is the hot wire, but since we do NOT know what type of instruments you have, we cannot tell you how YOU can do it.
  7. jc60618
    Dec 12, 2009
    Apprentice Plumber
    Chicago
    Am a plumber, the only electrical equipment I own is a craftsman multi-meter. I did take electric shop in high school six years ago and do know how to run wires to complete a circuit. I was just surprised to see that the hot and neutral wires were the same color.
  8. hj
    Unless it is in conduit, there were NOT when they were installed. In conduit the colors could be whatever the installer had, if he decided not to follow the convention of using white for the neutral.
  9. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    Find the cold negitive and the hot positive will be the ohter one.
Similar Threads: wires
Electrical Forum discussion & Blog Dual oven with 6 wires Nov 10, 2016
Electrical Forum discussion & Blog Controller or switch for thermostat wires Aug 22, 2016
Electrical Forum discussion & Blog How many #6 wires in 3/4 inch rigid conduit? Jun 8, 2016
Electrical Forum discussion & Blog STAPLING WIRES Feb 19, 2015
Electrical Forum discussion & Blog Lowering Ceiling: How to Extend Ceiling Light Wires Jan 1, 2015
