Brandon in VA
I'm remodeling a bathroom and the tub installation instructions recommend adding 1/4 furring strips on the studs down to the tub lip prior to installing 1/2 inch cement board that overlaps the lip. If I add the furring strips the thickness of the wall wouldn't line up with the rest of the room. What I'd considered doing in lieu of the furring strips is to put a short section of 1/4" cement board (maybe 12" high) as my "furring" above the front and back of the tub, then layer on another 1/4" cement board on top of that which is slightly longer (maybe 13") that would overlap the lip. The wall above the 1/4" cement board sandwich would be 1/2" thickness as would the entire back wall, which I could fur out without affecting the continuity of the wall thickness since it runs corner to corner. I suspect two 1/4" boards are flimsier than one 1/2" so I would nail blockings in behind for additional stability for tiling. Are there any issues with using two pieces attached together for this application, and should I put anything in between the two sheets? If not, anyone have another recommendation?
