two faucets one drain sink...can i use faucets with standard popup drain?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by naadimre, Dec 10, 2013.
  1. naadimre
    naadimre New Member
    Nov 30, 2013
    New York
    this is the sink we're installing. we're using the hansgrohe puravida faucets. i was wondering in this setup, do we just connect one of the popup drain assemblies and the other will be a dummy? the plumber seemed to think that since the drain is offset and not directly in front of the faucet, a touch or push drain would be better and not to use the popup drain at all.
    thank you!
  2. naadimre
    naadimre New Member
    Nov 30, 2013
    New York
    i posted the wrong picture, this is the 39 inch sink. we're installing the 47 inch sink. thanks.
  4. Smooky
    Smooky Well-Known Member
    Apr 4, 2011
    North Carolina
    You could go with a Push Pop-Up or just a flat strainer.
  5. naadimre
    naadimre New Member
    Nov 30, 2013
    New York
    just realized, i already purchased one faucet that has the pop-up assembly included and another that is without the assembly. looking at the faucet with the pop-up, the ball rod will be WAY too short. what do people normally do in this situation? is it easy to find a replacement extra long ball rod? the distance to cover will actually be about 12-13 inches!
  6. hj
    The problem with a longer rod is that it has to travel a much longer distance to move the popup plug open and closed. Few faucet popups have room for that much travel. But to extend the rod, you use a proper sized "rod coupling with two set screws" and a piece of plain rod the proper length.
  7. Terry
    Aug 17, 2004
    He could drill the sink and add the pop-up in the middle, centered between the two faucets.
    Or, I like what he mentioned about the push drain covers.
Similar Threads: faucets drain
Plumbing Forum, Professional & DIY Advice Boiler drain faucets for washer Jan 30, 2005
Plumbing Forum, Professional & DIY Advice New Moen Faucets - Leaking Drain Jan 29, 2005
Plumbing Forum, Professional & DIY Advice Bathroom sink faucets: ceramic cartridge vs. washerless cartridge;PVD nickel vs regular Saturday at 5:58 PM
Plumbing Forum, Professional & DIY Advice Plumbers- your preference for tub and shower valves/ faucets Feb 6, 2017
Plumbing Forum, Professional & DIY Advice Remodel cover plate for deck mounted bathroom faucets Jan 9, 2017
