Two designs of a new washroom for review
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Buttonsrtoys, Dec 16, 2012.
  1. Buttonsrtoys
    Buttonsrtoys New Member
    Nov 1, 2012
    Nova Scotia, Canada
    I'm adding a half-bath to on the first floor and tying into an existing sanitary line for the full bath above. Below are two designs. Design "A" runs the vent for the half-bath above the flood level of the fixtures in the full bath. Design "B" is a bit simpler on paper, but the existing riser is in an exterior wall next to a post at the point of the tie-in, so its a bit trickier to build than design "A". The sketches don't show the jogs in plan-view, which some lengths I relate may look out of scale.
    I annotated the sketches with ABS pipe sizes and lengths. Blue lines are the existing sanitary, green is the new.
    Are both of these designs OK? Code-wise, I'm in Nova Scotia.
  2. hj
    Desigh "A" is the only one that will work and that assumes you actually install it the way it is drawn. "B" would not pass any code that I am aware of.
  4. Buttonsrtoys
    Nov 1, 2012
    Nova Scotia, Canada
    Thanks hj. I'll install "A" as drawn. What's wrong with "B"?
  5. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    "B" is not acceptable because once the line has been used for a drain, it can no longer be used as a vent. The only exception is the wet vent of the water closet past the lavatory.
  6. kreemoweet
    kreemoweet Member
    Sep 7, 2009
    Seattle. WA
    "B" is the old "single stack" plumbing system design, as far as I know it was outlawed in the early part of the last century.
    Also, in "A", I think you need to keep the toilet/lav vent size at 2 inches all the way up, rather than reducing down to 1 1/2
    inch as shown.
  7. Terry
    Aug 17, 2004
    A
    And like mentioned above, keep the lav, including the vent, 2" all the way up to the next floor on the revent.
    You can use the 1.5" traparm for the p-trap on the lav.
    Below is an example of wet venting
    [​IMG]
  8. Buttonsrtoys
    Nov 1, 2012
    Nova Scotia, Canada
    Thanks guys. "A" it is with a 2" vent. Wet venting makes my head spin...
  9. hj
    quote; Wet venting makes my head spin
    Wet venting is simple, but your ""B" is an illegal "wet vent" because you cannot wet vent between floors.
  10. Buttonsrtoys
    Nov 1, 2012
    Nova Scotia, Canada
    Ah. That clarifies what was confusing me. So wet vents are OK provided their short/restricted to the same floor. Thanks! Now I'm curious - why are long wet vents between floors a problem?
  11. Terry
    Aug 17, 2004
    The same reason that standpipes can only be so long. They siphon traps.
Similar Threads: designs washroom
Plumbing Forum, Professional & DIY Advice New house planned: What's the best plumbing designs in the world? Sep 5, 2007
Plumbing Forum, Professional & DIY Advice Vent for basement 3pc washroom and laundry Jan 2, 2015
Plumbing Forum, Professional & DIY Advice Basement washroom rough in Sep 28, 2014
Plumbing Forum, Professional & DIY Advice No water pressure after bleeding. Should I cut the lines to my old washroom to fix? May 26, 2013
Plumbing Forum, Professional & DIY Advice Proposed Wet Vent for new three piece washroom. Nov 21, 2011
