two capped copper pipes protruding from concrete slab in basement
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Pickngrin, Feb 20, 2011.
  1. Pickngrin
    Pickngrin Member
    Sep 5, 2005
    Massachusetts
    My home was built in the late 1950s. I've got two copper pipes (see photos) protruding from the concrete slab. When we bought the house, we were told that they are not used for anything. Is there a way I can verify this so that I can know for sure that they are safe to cut and cover up?
    Thanks
    [​IMG]
    [​IMG]
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    The top picture looks like it is coming through the wall, not the slab. ??
    If so, go outside and start digging next to the foundation and see if you can tell where they are going.
    You might have a fuel oil tank or an old propane supply connection there.
  4. Pickngrin
    Pickngrin Member
    Sep 5, 2005
    Massachusetts
    I thought that was the slab. When we bought the house, we had received written confirmation that there was no below-ground oil tank.
  5. jadnashua
    There may have been one, and when it was removed, they left the pipes in place, and only removed the tank. You could take the plug out, but if it is connected to water, you'll get wet! At least that would tell you if it is connected to anything.
  6. Pickngrin
    Pickngrin Member
    Sep 5, 2005
    Massachusetts
    Is there a special tool (hm, this is a stupid question, isn't it?) to remove those plugs with the raised squares? My pipe wrench isn't doing it.
  7. jadnashua
    You'll probably need two wrenches: one to hold the fitting so you don't twist things too badly, and a second one to unscrew the plug.
  8. hj
    Loosen the plug, but do not remove it immediately until you see if anything leaks out as it gets looser.
Similar Threads: capped copper
Plumbing Forum, Professional & DIY Advice Whining coming from capped off pipe Friday at 7:38 AM
Plumbing Forum, Professional & DIY Advice SEWER GAS FROM CAPPED OFF BATHROOM OUT OF USE FOR LAST 15 years HELP! Jun 27, 2014
Plumbing Forum, Professional & DIY Advice Drain and Supply Capped For Future Use Jul 31, 2013
Plumbing Forum, Professional & DIY Advice Capped off drain50 gal. On w.h. ??????? I catch you i kill you Aug 20, 2012
Plumbing Forum, Professional & DIY Advice Uncapped Sewer Clean-outs pop up in Renos Nov 19, 2008
