OneProject
- Messages
- 2
- Reaction score
- 0
- Points
- 0
Hi all,
I'm trying to install a 3" Oatey Twist N Set closet flange on 3" short sweep copper drain pipe. The problem I'm having is that the Twist n Set is too long and cannot be inserted all the way due to the curvature of the copper pipe it is fitting into.
Secondly, it seems the seal between the gasket and inside of the copper is REAL tight and I'm tempted to use some lubricant to be able to install it without destroying the gasket. If the pipe were a few millimeters larger in inner diameter, I wouldn't have this problem. lol.
A few questions:
1) If I saw off part of the twist-n-set downpipe so it will fit, will it still work?
2) Can I apply a little lubricant (mineral oil?) to facilitate installation of the shortened closet flange?
3) If not, are there any other easy to install closet flanges for this application? I can't seem to find a copper flange for the life of me and I'm afraid if I do, it is going to be in the $50 to $100 range....
Thanks,
Steve
A few questions:
Thanks,
Steve
