Turning on sprinkler for spring
Discussion in 'Irrigation / Sprinkler Forum' started by Fred44, Mar 14, 2012.
  1. Fred44
    Fred44 New Member
    Mar 14, 2012
    North Carolina
    Just had an 8 zone irrigation system installed last fall & was winterized. I have what appears to be a master valve underground in my front yard directly off the main water shut off. It has a yellow handle that is currently perpendicular to the pipe (like a 'T'). The side of the house has above ground cover with a regular hose on/off handle (circular) and two blue handles that are both horizontal (in line) with the pipe.
    Above ground housing: http://www.flickr.com/photos/76128187@N04/6836508658/
    Below ground valve: http://www.flickr.com/photos/76128187@N04/6836507782/
  2. Mitchgo
    Mitchgo New Member
    Jan 27, 2012
    Seattle
    Connect your Back Flow Assembly back up with the Unions. ( Reduced Pressure Back Flow Assembly) and then slowly open up the yellow handle in the inground box.
  4. Mitchgo
    Mitchgo New Member
    Jan 27, 2012
    Seattle
    Next time if they disconnect the rp, they need to cover up those openings so debris won't get inside of the system.
  5. cswanson
    cswanson New Member
    Mar 16, 2012
    Albertville, MN
    Glad you winterized. You'd be surprised at the number of people we see who opt not to do that, and we're up north in MN.
  6. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I take my BF out each fall and store it inside just in case there is any water left inside. These double check valves are too expensive to risk having one freeze and break. Then I use small plastic food storage bags and heavy rubber bands over the exposed union ends to keep debris out. It doesn't have to be air or water tight.
Similar Threads: Turning sprinkler
Irrigation / Sprinkler Forum Turning on in ground sprinkler system for spring May 6, 2009
Irrigation / Sprinkler Forum Trouble Turning Sprinklers On This Spring Apr 26, 2008
Irrigation / Sprinkler Forum Turning on Sprinkler for Spring Apr 23, 2008
Irrigation / Sprinkler Forum Sprinklers turning on and off sporadicly. May 4, 2007
Irrigation / Sprinkler Forum Turning on sprinkler system in spring Apr 19, 2006
