turning off a lamp
Discussion in 'Electrical Forum discussion & Blog' started by v1rtu0s1ty, Dec 22, 2008.
  1. v1rtu0s1ty
    v1rtu0s1ty DIY Senior Member
    Sep 18, 2006
    Chicago IL
    Hi folks,
    I'm going to build a mini greenhouse for a plant. Inside this mini greenhouse is a 100 or 150 watt lamp. I'm looking for a cheap solution that can turn OFF this lamp when temperature inside greenhouse reaches 40F. It can also turn the lamp to ON when temp inside greenhouse goes down to 30F. I'm not really good in electrical so I don't know what to look for. Right now, I'm thinking thermostat but that's it.
    Are there products like this?
  2. jar546
    jar546 In the Trades
    Feb 20, 2008
    USA
    First buy a thermometer and install it inside your house near a window that faces the greenhouse.
    Next install this product and use it whenever you see the temperature at the limits you want:
    [​IMG]
  4. jar546
    Feb 20, 2008
    USA
  5. v1rtu0s1ty
    Sep 18, 2006
    Chicago IL
    Awesome. I will contact them tomorrow. Thanks for the link. ;)
    So looking at the link, what I really need is the heating outlet. That is an awesome product!
    Thanks again!
  6. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    The thermostat contacts have to be able to handle a tungsten load. If you can't find one, you need to have the tstat control a relay that can handle a tungsten load.
  7. jimbo
    jimbo Plumber
    San Diego, CA
    I will go out on a limb and say that any product which is designed to have a regular AC plug plugged in to it will be adequate for a 100 watt flood bulb. But of course, I am sure the manufacturer can provide a detailed spec sheet to be sure.
  8. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    MD
    And I will be busy sawing off the limb you are on!:p
    You're probably right. This is not some huge incandescent or motor load.
Similar Threads: turning lamp
Electrical Forum discussion & Blog Appliances turning on Jul 16, 2013
Electrical Forum discussion & Blog Lights turning themselves on (Ghost in the machine)? Aug 26, 2010
Electrical Forum discussion & Blog Replace weatherhead without turning off service? May 23, 2008
Electrical Forum discussion & Blog Halogen lamps inquiry Apr 21, 2016
Electrical Forum discussion & Blog Lamp in Middle of Room (Need Power Supply) Apr 19, 2012
