turned around hot&cold
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by nan, Apr 16, 2005.
  1. nan
    nan New Member
    Apr 14, 2005
    so if i moved a water heater (temporary) to another space and hooked everything up then realized that i had the hot and cold water pipes swiched would it matter that much?? would it just run everything backwards?? this is just a temp move for a few days
    any advise?
    thanks nan
  2. Plumber2000
    Plumber2000 Plumber
    Jan 13, 2005
    Eugene, Oregon
    If you like hot water to the toilet, hot water to ice maker if you have one, and all faucet reversed when turned on, then no it will not matter,
  4. hj
    h&c
    It will have no effect on the icemaker, faucets, or anything else. You WILL run out of hot water sooner since you will just be using the lower third, or less, of the tank's hot water. Just criss/cross the connections if you used flexible connectors to install it.
  5. nan
    nan New Member
    Apr 14, 2005
    Thanks hj
    thanks for the helpful info hj :)
    nan
Similar Threads: turned around
Plumbing Forum, Professional & DIY Advice Turned one shut off valve now there is NO water in bathroom sink. HELP Dec 24, 2016
Plumbing Forum, Professional & DIY Advice Knocking sound when hot water is turned on Jul 10, 2016
Plumbing Forum, Professional & DIY Advice Delta shower valve, No hot water in shower turned into problem with Delta valve? Mar 19, 2016
Plumbing Forum, Professional & DIY Advice Buying a house - water/electric turned off in November, no winterization Feb 17, 2016
Plumbing Forum, Professional & DIY Advice kitchen faucet leak underneath when hot water turned on Sep 20, 2015
