Turbo Torch
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Jeff lange, Feb 25, 2007.
  1. Jeff lange
    Jeff lange New Member
    Feb 25, 2007
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    That's almost a $280 set up there so don't expect that reserve price to be hanging low.
    It's all I've used over the years. I love the push-button ignitor attachment and the large tip is great for heating up poured lead joints.
    I run with MC tanks with the adaptor for the item you are looking at.
  4. RioHyde
    RioHyde Plumber
    Sep 24, 2004
    Cincinnati, Ohio
    Unless you're in the business of using a torch quite a bit, I dont see the need for a B tank, but hey...that is one man's opinion. Like Rugged, it is what I use, but only for commercial plumbing (my "regular" job)....which is 95% of the time. For working on my own on residential projects, I just use a small MAPP gas setup. Works great and I'm not lugging that big tank around the customer's house. If you're dead set on a Turbo Torch, but you wont be using it frequently, check into the same setup, but with the small tank and regulator (MC). Its alot less cumbersome.
    [​IMG]
  5. markts30
    markts30 Commercial Plumber
    Sep 25, 2006
    Commercial Plumber
    Phoenix, AZ
    It's all I use - B tank and Turbo Torch - good for soldering all sizes of pipe up to 5" copper and brazing up to 2.5"...
  6. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    turbo torches
    that top set up is all you really need.....
    the LARGE B tanks are a pain in the butt and weigh too much
    for average service work.....they are best for heavy
    construction jobs only..... my opinion only
    dragging a B tank across a tight crawl space
    getting it covered in mud, then going to the next call and
    laying it down on a ladies kitchen floor with gravel
    still stuck to the bottom of it does not go over too good.....
    or hauling one down a flight of stairs gets very old
    after a while....
    they get very, very heavy by the end of the day
    I have that top set up with the larger torch tips...
    and its been adapted down to the smaller " mc tanks." ...
    it has less volume, but its a fourth the weight and
    worth the trade off
    I carry 2 extra mc tanks with me for a back up.
  7. coz
    coz New Member
    Feb 27, 2007
    MA
    I use a small map torch too ..all i need.. unless you work on 4 inch mains all the time. its overkill. my setup fits in my toolbox
Similar Threads: Turbo Torch
Plumbing Forum, Professional & DIY Advice Cleaning turbo torch tips? Feb 17, 2008
Plumbing Forum, Professional & DIY Advice I have a turbomax water heater w/oilburner and want to add electric Nov 15, 2015
Plumbing Forum, Professional & DIY Advice Torch head for propane vs. mapp? Jul 5, 2016
Plumbing Forum, Professional & DIY Advice Torch/solder temp Jun 13, 2016
Plumbing Forum, Professional & DIY Advice Which soldering torch.... Apr 21, 2016
