Tube support liner removal in Shark Bite?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by lisa99, Sep 24, 2007.
  1. lisa99
    lisa99 New Member
    Sep 16, 2007
    Nevada
    In another Shark Bite-related thread, NYplumma says "Remember, if you're using them on copper pipe, take the plastic insert out."
    The instruction sheet for installing the product says the tube support liner "may" be removed for copper and CPVC.
    I replaced a mixer valve last weekend and used Shark Bite for the new joints. I have copper pipes, everything is in place and there are no leaks, but I didn't remove the inserts. The wall is still open. Should I go back and remove the inserts and if so, what would be the reason for doing so?
    Thanks as always for your help and advice,
    Lisa
Similar Threads: Tube support
Plumbing Forum, Professional & DIY Advice When am I supposed to use Brass tube support sleeve Sep 8, 2006
Plumbing Forum, Professional & DIY Advice Overflow tube under sink that seems to no longer exist Jan 17, 2017
Plumbing Forum, Professional & DIY Advice Weird thing with flushomatic toilet; tube connecting pipe to wall Aug 30, 2016
Plumbing Forum, Professional & DIY Advice Triangle Tube Error E03 / E 03 Aug 12, 2016
Plumbing Forum, Professional & DIY Advice Kitchen Sink drain needs to lower; could I swap drain with stand tube? May 13, 2016
