Tub to Shower Conversion
Discussion in 'Shower & Bathtub Forum & Blog' started by shamrock_94, Nov 21, 2006.
  1. shamrock_94
    shamrock_94 New Member
    Nov 21, 2006
    Michigan
    From reading on this and other boards, I see that in order to to convert a tub/shower to a shower I must replace the 1.5" waste line with a 2" waste line. I understand this is code, but can anyone explain the rationale? I don't see the difference between using a tub/shower and a shower. If I take a shower in a tub/shower or a shower stall, the water use would be the same. What gives?
    thanks in advance.
  2. Lancaster
    Lancaster New Member
    Nov 7, 2005
    A shower needs to drain faster than a tub.Tub has a lot more capacity than a shower does,will take much longer to flood and overflow.
  4. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    A shower has less storage capacity before it runs over. A 1.5" drain in a shower will probably work fine if the drain is good. It is even less of a problem if you have the 2.5 GPM limit of modern showers.
    The codes are made to deal with worst cases. It could be a problem if you installed one of those multihead body wash things that use 10 to 12 gallons per minute of water from 4 or 5 heads.
    If you can get it past the inspector, you can probably get by with the 1.5" drain. If you are doing the plumbing yourself, you can deal with it as you wish.
Similar Threads: Shower Conversion
Shower & Bathtub Forum & Blog Shower replacement, 1.5" to 2" conversion - do I need to replace vent pipe too? Sep 9, 2016
Shower & Bathtub Forum & Blog bathtub to shower conversion Sep 7, 2013
Shower & Bathtub Forum & Blog Bath to Tile Shower Conversion Aug 22, 2013
Shower & Bathtub Forum & Blog shower to tub conversion Jun 2, 2013
Shower & Bathtub Forum & Blog Looking for this part or conversion for American Standard Push Pull shower. Feb 22, 2013
