tub to shower change
Discussion in 'Shower & Bathtub Forum & Blog' started by gg_murray, Nov 16, 2005.
  1. gg_murray
    gg_murray New Member
    Nov 16, 2005
    Hello everyone,
    I know that the 1 1/2 tub drain has to be extended to accomodate the center outlet of the shower and that a shower has a 2" drain. But can an adapter be used to increase the 1 1/2 tub drain to 2" and then extend with the line with 2" and a 2" trap? Or will the complete run need to be increase to 2"? Also will concrete around the drain need to be poured up with tar similar to the tub drain or should the opening be poured up with concrete? The tub is being replaced because the owner is having a knee replacement and won't be able to get over the ledge of the present tub. Thanks for any help!
    Greg
  2. jadnashua
    You can't go from 2" down to a smaller diameter at all, so you will need to replace that tub drain line back until where it is at least 2". A friend had a knee replacement awhile ago and it is now much more flexible than it has been for the last 20 years. But, that is another story.
Similar Threads: shower change
Shower & Bathtub Forum & Blog Shower head sizes???did they change? May 30, 2016
Shower & Bathtub Forum & Blog Change Delta Shower Catridge Mar 27, 2016
Shower & Bathtub Forum & Blog Change ShowerHead at Attachment Sep 5, 2012
Shower & Bathtub Forum & Blog How to remove or change old rotating shower head with wide connection? Dec 29, 2010
Shower & Bathtub Forum & Blog Tub Shower Stem Interchangeability Jun 27, 2010
