Tub surround question
Discussion in 'Remodel Forum & Blog' started by khayes, Nov 4, 2011.
  1. khayes
    khayes Member
    Oct 25, 2005
    Alpharetta, GA.
    I've just finished installing a new Roman tub faucet where I had to remove a section of tile and backer board to gain access to remove the old fixtures and install the new ones. The builder did not provide an access panel. My question is: do I have to go back an re-install backer board or can I use 1/2" birch plywood or even drywall as a backer. I already have both on hand. The area in question is 4 6x6 tiles, the surface is vertical and is not really subject to moisture. I hate to buy a whole piece of CBU for this small area. Also, can I use a pre-mixed thinset or mastic to replace the tiles?
    Thanks.
  2. jimbo
    jimbo Plumber
    I do recommend treating as a wet area. But one way would be to use the plywood , tape the seams with fibrelgass tape and the mastic, and coat with Redguard. Of course a gallon of Redguard will cost about the same as a sheet of backer board! But is easier to handle, and you might later have other uses for the leftovers.
    Premixed thinset is ok. Mastic is fine, but technically in a wet area be sure to get a mastic listed at TYPE 1
Similar Threads: surround question
Remodel Forum & Blog Tub surround question Dec 24, 2006
Remodel Forum & Blog Can I install a tub now and put up a cheap surround then tile later? Feb 6, 2016
Remodel Forum & Blog Tub/shower surround Jan 22, 2012
Remodel Forum & Blog shower remodel -- trouble leveling the shower surround -- help! Aug 2, 2010
Remodel Forum & Blog How do I trim an acylic tub surround? Jan 25, 2009
