Tub spout rough in for Tub/shower renovation
Discussion in 'Shower & bathtub Forum & Blog' started by lemmy, Dec 18, 2013.
  1. lemmy
    lemmy New Member
    31
    knoxville, tn
    I have a new cast iron tub and will be installing tile on the 3 walls surrounding the tub. I have a delta MultiChoice valve (the pex version). So I will crimp pex to the incoming lines, then I will screw a pipe thread to pex adapter on to run pex up to the shower where I will have a drop ear elbow that I will crimp pex too. Then I will screw a 1/2 pipe nipple in for now. For the tub spout I am coming out with a pipe thread to copper sweat adapter then running copper down. At that point should I just put a sweat elbow and have a copper tube coming out (for a slip on tub spout) or should I instead have a drop ear elbow and come out with a a pipe nipple (like for the shower)? At this time I do not know what delta hardware I will be using so I don't know if I am better off going with copper pipe (slip on) or pipe nipple (thread on spout)? Is one more common, what happens if I do one but the spout is only available as the other? Thanks.
  2. dj2
    dj2 Member
    409
    California
    Either way is acceptable. I like the drop ear - it's easy to secure to a block.
  3. hj
    26,540
    Your Delta spout "should" have a "unifit" adapter which can attach to either threads or solder to a copper stub, so you can do it either way. But, DO secure the elbow somehow, even if it is not a drop ear elbow, which is what most plumbers WOULD use.
    [​IMG]
    [​IMG]
  4. lemmy
    lemmy New Member
    31
    knoxville, tn
    Thanks for the help!. So how far should I have the 1/2 nipple sticking out from the finished wall? Fortunately this is something I can change after I finish the wall, but I would like to do a leak test on the drop ear/nipple interface before I put up the tile. It always makes me nervous to screw in a new shower pipe and not be able to see in to check for leaks. If I can have the right length nipple in that would be one less that I would have to worry about. Thanks!
  5. dj2
    dj2 Member
    409
    California
    Measure from the drop ear to the finish wall.
    Measure from the thread to the base in your spout.
    Add the two - and there is your nipple length.
    Remember: get 2 more nipples, one slightly longer and one slightly shorter, if your calculations turned out to be wrong.
  6. jadnashua
    21,950
    The Delta spout with the adapter HJ shows is pretty flexible. The O-ring makes the seal, so as long as you can screw it on, it'll work. The spec sheet gives a fairly big range. Most other spouts that screw on are much less flexible.
  7. hj
    26,540
    With that adapter the nipple can project 1 1/2" from the wall, but it means a lot of "twisting" to screw the spout on that far. I like it as close to the wall as possible form that reason.
Similar Threads: spout rough
Shower & bathtub Forum & Blog Bath spout rough-in/Nipple or Sweat Sep 8, 2009
Shower & bathtub Forum & Blog Tub Spout Rough In Aug 8, 2008
Shower & bathtub Forum & Blog shower valve causing leak through tub spout Sep 21, 2006
Shower & bathtub Forum & Blog Tub Spout Occasionally Discharges Water Jun 25, 2014
Shower & bathtub Forum & Blog Options to reattach or replace tub spout Feb 9, 2014
