ARB
Hi,
I’m in the processing of installing new alcove tub, valve and spout. I will be reconfiguring the plumbing using pex, and I’m trying to sort out the details of plumbing the tub spout. The waterfall-style spout is attached to a “spout adapter” which has a 1/2” male threaded connector for joining it to the plumbing. My thought was to connect the valve to a drop ear elbow, and then use a brass nipple and 1/2” x 1/2" female threaded coupler to complete the connection to the spout adapter (as shown below)...
When I put the assembly together by hand (without using tools), I have noticed significant variation in how much the pieces screw into each other, which makes me think that this might be normal… Sometimes it screws in (by hand) only a few turns (less than 1/4”); sometimes it’s closer to 1/2”.
On a related note, in trying to figure out where to place the mounting block for the drop ear elbow, it also now occurs to me that I would need to “permanently” join these pieces and measure the final length of the assembly, in order to place the mounting block in the right location… (There is no “play” in how the tub spout attaches to the tub adapter, so the mounting block location is critical to having minimal gap between the escutcheon plate and the spout.
So, here are my questions:
-- Is the plumbing configuration described above a reasonable approach?
-- Is the variation I experienced when screwing the pieces together by hand “normal”? Or should I try to replace the fittings with ones that allow for deeper connections?
-- Is my thinking correct about permanently assembling the pieces and then figuring out exactly where to attach the mounting block to the studs?
Any and all advice is greatly appreciated… Thanks very much!
