Tub spout -- broken pipe
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by adman, Apr 1, 2007.
  1. adman
    adman New Member
    Apr 1, 2007
    Hi all... The goal was to remove an old tub spout and replace it with a new one.
    Well, when I was unscrewing the old spout, what I was actually doing was twisting and torqueing the copper pipe about 3 inches inside the wall.
    When it broke loose, I now have a tub spout in my hand, still attached to a short length of copper pipe (is this a "nipple"?).
    Any idea of how I can proceed? Is it possible to replace the pipe that the tub spout normally screws on to?
    Thanks for any advice you can provide!
    Adman
  2. jimbo
    jimbo Plumber
    Unfortunately , there is every liklehood that the copper stub out is soldered to an elbow inside the wall. You will need access into the wall, either from the front through the tiles, or preferably through the back side of the wall if that is accessible.
  4. TedL
    TedL New Member
    Sep 17, 2006
    NY Capital District
    If the pipe that came out broke loose at the fitting it was sweated into, there is a chance you could clean out the fitting with a wire fitting brush and sweat the pipe back on by applying heat to the pipe. You'd need clearance around the pipe to get the solder wire in to the fitting.
    But I have to say that if the sweat connection broke loose from twisting, it was not a good connection to begin with, and the connection on the other side of the elbow is probably no better.
  5. adman
    adman New Member
    Apr 1, 2007
    Hi Jimbo... I'm beginning to get this impression as well.
    I tried using a removal tool (that grips the pipe from the inside) to remove the leftover piece from inside the wall, but the small fitting seems to be too small, and the medium fitting seems to be too big.
    Looking at the pipe that is still attached to the tub spout, I can see that there is some sort of soldered connection inside the length of the tub spout. For the life of me, I can't remove the actual spout from that short length of pipe.
    I have a feeling I'm outgunned here. If anyone can reccomend a good, honest, friendly plumber in the North San Diego county area, maybe email me at aspragg@yahoo.com? Thanks for your replies.
    Adman
  6. adman
    adman New Member
    Apr 1, 2007
  7. Roy Nakamura
    Roy Nakamura New Member
    Mar 7, 2007
    Adman...you must be one strong guy :p
    I'm not a plumber...but maybe a plumber will chime in. Is it possible to touch the remains of the copper pipe through the tile hole and heat it in such a way so you can pull out the remaining copper line from the fitting? (then wire brush the fitting, clean and flux)
    I could see if you could do that...then place a clean copper pipe through the hole...heat her up...then feed a line of solder in the gap between the pipe and the tiled opening...
  8. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    You're looking at probably a $300 repair on a sunday evening.
  9. adman
    adman New Member
    Apr 1, 2007
    It may appear so, but really, I'm not! I never felt like I was applying enough force to come close to ripping through copper pipe.... But yet, here we are.
  10. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    It may be possible to clean up the elbow and replace the nipple with a new one, however it's not an easy task to get the inside of a fitting cleared of solder enough for a new pipe to fit into even in ideal conditions. If you try to heat the solder in the old fitting so the new piece will slip in, chances are pretty good you'll burn the flux off and solder won't flow into the joint. You'd be better off in the long run to access the area so you can work on in with at least some room to work and replace the old used fittings with new.
  11. TedL
    TedL New Member
    Sep 17, 2006
    NY Capital District
    Can you get access from behind? Hopefully, it backs up to a closet, but even if it's just painted drywall, that's the approach you'll want to take.
  12. adman
    adman New Member
    Apr 1, 2007
    Unfortunately not (maybe).
    The wall behind it is a wall with a full floor-to-ceiling, wall-to-wall mirror mounted on it. It must be glued on, or something, since I don't see any brackets that could be easily unscrewed for removing it.
    Another question: IF we have to go in through the tile side, can the tile squares be saved and re-used? Or does this mean finding matching tile, OR retiling the whole tub?
    Thanks for all your responses so far!
    Adman
  13. Roy Nakamura
    Mar 7, 2007
    Adman...maybe it's time to get a quote on replacing the mirror :confused:
    As I said before I'm not a plumber and as a landlord I have done many 'creative' repairs...something I'd never try or do for my own home.
    First I'd try the heat and attempt to clean out the elbow...and if that didn't work...
    Next..if I didn't plan on replacing the entire shower surrond in a remodel I'd get price quotes for replacing the mirror.
    If it were for a rental...I'd take a Drimmel tool to the grout lines and remove the required tiles (which is more than likely going to crack) and cut threw to the vertical pipe thingie between the value and the elbow of the spout. Cut then splice a little vertical pipe thingie with the elbow and nipple...and do some green board, thin set magic. Again...something I wouldn't do on my tiled shower...
  14. TedL
    TedL New Member
    Sep 17, 2006
    NY Capital District
    Aparently you didn't have the mirror installed. I'd check with a glass place that does that kind of work to see if there are non-destructive ways to R&R the mirror.
    If you remove the grout and are careful not to crack tiles, they can generally be removed, cleaned up and replaced. Paint remover will generally get off any adhesive, if that's what was used. Thinset can usually be scraped off.
    You don't want grout lines to line up with wall surface patch lines.
    Don't use greenboard unless that's what's already there, in which case there's no point in making a patch better than the surrounding 60 ft. sq. Use wonderboard, hardibacker or other CBU.
  15. hj
    spout
    You have the worst situation, because there is no way to remove the broken pipe of tubing from the elbow without having access to that elbow it is soldered into. Even if you could heat it hot enough without opening the wall, you would probably start a fire inside the wall and possibly burn the house down.
Similar Threads: spout broken
Plumbing Forum, Professional & DIY Advice Delta Tub Spout Installation Questions Jan 10, 2017
Plumbing Forum, Professional & DIY Advice Front end threaded spout? Nov 16, 2016
Plumbing Forum, Professional & DIY Advice Stubborn tub spout.. help! Nov 14, 2016
Plumbing Forum, Professional & DIY Advice Gutter downspout drainage Oct 18, 2016
Plumbing Forum, Professional & DIY Advice Black goo on spout opening Aug 1, 2016
