Tub/shower pics
Discussion in 'Shower & Bathtub Forum & Blog' started by SH140, Aug 4, 2013.
  1. SH140
    SH140 New Member
    Jan 31, 2013
    Vallejo, Ca.
    After dozens of questions to this group, I finally got this project to the point where I can post some pictures. Still not fully completed, but getting there.
      File size:
      44.9 KB
      264
      File size:
      49 KB
      267
      File size:
      50.2 KB
      267
  2. Terry
    Aug 17, 2004
    That's looking very nice. :)
  4. SH140
    SH140 New Member
    Jan 31, 2013
    Vallejo, Ca.
    Thanks Terry, and thanks for the advice along the way.
    Is it necessary to fill tub with water before caulking gap between tub and bottom row of tile if tub is set in a mortar/cement bed?
  5. SH140
    SH140 New Member
    Jan 31, 2013
    Vallejo, Ca.
    Soon I will caulk with silicone around the tub between the tub and bottom row of tile. My wife asked me if I was going to fill tub with water before I caulked. I don't think it's necessary because tub is set in a bed of mortar/concrete, but figured I'd ask beforehand just to be sure. What do you say?
    __________________
    Steve
  6. SH140
    SH140 New Member
    Jan 31, 2013
    Vallejo, Ca.
    You'd think that being so close to the end of the project I'd run out of questions, but here's another..............I'll be tiling the vanity top, can I use 3/4" Birch interior plywood for the top under the tile? If so, should I put a coat of paint on it first? Or maybe HydroBan?
    I have a roll of Ditra, is it necessary for a countertop?
  7. jadnashua
    Birch is pretty stable, but, it is unlikely that it has waterproof/resistant glue...I'd pass on it and use some ply that does...OR, consider using a chunk of KerdiBoard...just use KerdiFix to attach it to the top of the vanity and tile away. Really easy with a top mount sink, a little tougher with an undermount.
  8. hboogz
    hboogz Member
    Mar 12, 2013
    New York
    Awesome work. I'm no pro, but it certainly looks good. Do you have pics of the finished counter ?
  9. SH140
    SH140 New Member
    Jan 31, 2013
    Vallejo, Ca.
  10. jadnashua
    FWIW, on KerdiBoard, it is the foam that is the waterproof component...the orange surfaces are for compatibility to mortar. In fact, you can poke a hole through that, and as long as it does not penetrate all the way through to the other side, not ever worry about sealing it. Those orange surfaces can wick moisture, but that's irrelevant. As long as the edges are properly sealed with Kerdifix, and the through holes either covered with Kerdiband, golden. You're missing a lot of flexibility and speed by ignoring it as a product. You can do more with it in an hour than you could in several days of building a structure like a drop in tub deck or a counter.
    Nice looking remodel, however you ended up deciding.
Similar Threads: Tub/shower pics
Shower & Bathtub Forum & Blog Help identify tub/shower trim Feb 3, 2017
Shower & Bathtub Forum & Blog Bathtub/shower enclosure product choices Jan 26, 2017
Shower & Bathtub Forum & Blog New tub/shower set up, not enough water pressure Jan 16, 2017
Shower & Bathtub Forum & Blog Valve layout for tub/shower?????????? Jun 11, 2016
Shower & Bathtub Forum & Blog Tub/shower valve replacement, Galvanized to PEX? May 29, 2016
