Tub & Shower Installation
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by LarryD, Aug 21, 2005.
  1. LarryD
    LarryD New Member
    Aug 1, 2005
    I am installing a one piece tub & Shower unit (30" x 60") in a new bathroom I am building in my basement. One end of the unit will be against the end wall and I will build a short wall at the other end. Do I have to make sure there is a stud exactly 30" from the back wall, and if so, is that 30" to the center of the stud, or to the outside edge? I assume after the unit is in place I secure it to the stud walls by using the sheetrock screws thru the sheetrock and the lip on the unit. Is that correct? Is there a web site that explains that in detail? I am doing the carpentry myself and having a plumber rough in the plumbing and install the tub, commode, vanity, etc. so I want to make sure my walls are correct.
  2. Deloris
    Deloris New Member
    Aug 20, 2005
    If you know the mfg. of your unit you should be able to get rough-in dimensions on the internet. The company should have spec sheets for all of their products on their site. If they don't their customer service should be able to email or fax it to you.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Fiberglass showers are fastened to the studs with nails or screws before the drywall (greenboard) is hung. You will want a stud, on the end to solidify the unity. When I did my 30x30, I used a double stud because I was going to hang a door. That might have been overkill, but 2x4s are cheap enough. You will also want to install the unit on a bed of mortar to take the spring out of the floor. I used a bag of Armstrong Floor Leveler and just poured it in the space after the unit was totally anchored and the drain was connected. I used this instead of mortar because I had an extra bag on hand. The unit should have an installation sheet with it, but if not, get one online from the manufacturer.
Similar Threads: Shower Installation
Plumbing Forum, Professional & DIY Advice Shower Drain Installation Tuesday at 10:40 AM
Plumbing Forum, Professional & DIY Advice Stainless Steel Shower Base Installation Mar 6, 2014
Plumbing Forum, Professional & DIY Advice Shower/tub trim installation help Dec 31, 2013
Plumbing Forum, Professional & DIY Advice Shower drain installation plywood subfloor May 29, 2011
Plumbing Forum, Professional & DIY Advice kohler shower drain installation May 7, 2011
