OK, I'm an idiot, I admit it. Remodeling bathroom, new plumbing and all. I hooked up the tub drain to the p-trap before installing the tub (solvent weld PVC). Now with the tub in and Durock up, I go to hook up the drain and notice the shoe is not even with the tub bottom. It's twisted a bit, about 1/8 inch gap on one side when the other side makes contact. The thin rubber gasket won't seal this, so can I use a thicker gasket, like on the overflow fitting? What are my options?
Access to the pipes is very restricted and will be difficult (be maybe not impossible) to cut out and try again.
