tub overflow pipe won't budge to replace gasket
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by tbbarch, May 24, 2013.
  1. tbbarch
    tbbarch Member
    Sep 24, 2008
    Virginia
    I've done a couple overflow gasket replacements and there is always some flex in the pipe to pull out the old overflow gasket and replace it.
    The tub in question is a cast iron niche tub from 1965 with a flat overflow gasket. I removed the cover plate and could not with moderate force get any movement in the pipe by pushing from the tub or gripping and forcing to the side or pulling from the back or applying some leverage off the tub with a screw driver.
    How much force is reasonable on the brass pipes to get them to separate from the gasket?
    Should I use a hammer and block of wood and tap it sideways from the back or to push it out from the tub side?
    Should I try to hammer a scrapper blade under the gasket from the back side?
    Is there a way to know if the gasket has the pipe "glued" to the tub or if the pipes are just so inflexible?
    LAST THING this repair needs is for the pipes to need replacing.
    Thank you
  2. Winslow
    Winslow Plumber
    Dec 30, 2005
    Hawaii
    Just seal the overflow with propoxy and call it good.
  4. hj
    I have seen many brass tub drain assemblies which were soldered together and there was no movement possible with them. Whether yours will have any movement without breaking anything is something we cannot answer.
  5. jadnashua
    Is it possible that they silicone the gasket in place? IF so, it's a bear to remove.
Similar Threads: overflow pipe
Plumbing Forum, Professional & DIY Advice Washing machine drain pipe overflows when I take a shower Jun 25, 2016
Plumbing Forum, Professional & DIY Advice Leaking overflow pipe from combo cylinder Feb 18, 2015
Plumbing Forum, Professional & DIY Advice open sewage overflow pipe in old basement? Apr 27, 2014
Plumbing Forum, Professional & DIY Advice Connecting condensate pump to tub overflow pipe Sep 17, 2013
Plumbing Forum, Professional & DIY Advice My washing machine drain pipe keeps overflowing Jan 5, 2013
