Tub overflow need to be straight?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by inexplorata, Oct 22, 2008.
  1. inexplorata
    inexplorata New Member
    Oct 22, 2008
    Colorado
    Hey all, I've been reading this forum like crazy, tons of good stuff here.
    I'm dropping in a new deck-mount tub upstairs, and I picked up a groovy cable-driven overflow/stopper dealie. The tub is deep -- 33 inches from drain to lip -- and it's a center drain I've got nearly filling the far wall of the bathroom.
    I've got the waste roughed in fine, but the overflow coming straight down (as it usually would, to meet the drain waste pipe) would mean still more holes in a perfectly good floor joist (they run parallel to the tub). I feel like I've probably put as many holes in it as I should :D Would it be OK to turn the drain line 90 degrees and have the overflow sort of wrap around the tub a bit (keeping a good slope) and come down? In other words, would another foot or two of pipe in that overflow line be a problem?
  2. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    Yes, it's OK to do this. From the tub, slope the overflow pipe so it goes horizontal, with a minor slope, and then have the pipe turn down above or near the spot where it will connect to the tub drain. Which fitting will you be using at that point?
    David
  4. inexplorata
    Oct 22, 2008
    Colorado
    I figured a sanitary wye and a 1/8th bend, or a combo, depending on how much wiggle I need.
    I had another thought: what about wrapping that overflow all the way around (with a little drop along the way) and coming down on the other side of the tub? Then I'd be pretty much in line and could do all the below-tub work between two joists... and before you ask, I don't want to just flip the tub 180 degrees, because then the first thing you'd see looking at it would be the overflow, which might take away from the ungodly-expensive roman tub filler my wife wants. :)
  5. geniescience
    Nov 27, 2005
    ditto
    Fantastic thinking. You are welcome to stick around here and contribute for ten or twenty years. : - )
    A way to kill two birds with one stone is to buy a "Geberit Integrated Cascading Tub Filler and Bath Waste/Overflow" http://www.terrylove.com/forums/showthread.php?t=7037 . It puts the water spout in the same place as the overflow.
    Then, you get to enjoy one_fewer_piece of expensive chrome to look at when you enter the bathroom. Cleaner lines.
    David
  6. Jay Mpls
    Jay Mpls Master plumber
    Sep 29, 2008
    Master Plumber /Sewer rat
    Minneapolis
    Can you get ahold of what is called a direct drain? In other words it drain into the trap from the waste outlet instead of going straight down from the overflow.Hope this helps.
  7. hj
    spout
    Unless that unit has an air gap/backflow preventer it is completely illegal. The spout has to be at least 3" above the tub. That spout is the same as the ones in the indirect waste tubs made 100 years ago and went out of business for the same reason.
Similar Threads: overflow need
Plumbing Forum, Professional & DIY Advice Need help with persistent tub overflow leak. Nov 24, 2016
Plumbing Forum, Professional & DIY Advice New Tub Installation - Drain/Overflow Help Needed Dec 6, 2015
Plumbing Forum, Professional & DIY Advice Sink overflowing Alzhiemer's - need metering push faucet? Nov 14, 2006
Plumbing Forum, Professional & DIY Advice How should this humidifier overflow be plumbed? (pics) Jan 24, 2017
Plumbing Forum, Professional & DIY Advice Overflow tube under sink that seems to no longer exist Jan 17, 2017
