Tub overflow leak into bathtub
Discussion in 'Shower & Bathtub Forum & Blog' started by Cathy, Dec 13, 2004.
  1. Cathy
    Cathy New Member
    Dec 13, 2004
    Hello, My bathtubs' overflow valve recently started leaking. The amount of water that is coming out is between a fast drip and a steady stream. It runs from the bottom of the overflow cover down into the bathtub drain. Do I need to just replace the overflow cover (which looks like it could use replacing) or could this be something more serious?
  2. jimbo
    jimbo Plumber
    San Diego, CA
    This needs immediate attention. If water is coming out the overflow, you either have a major blockage on the drain line; or you have a leaking pipe or fitting inside the wall and the water happens to find its way through the overflow cover.
Similar Threads: overflow leak
Shower & Bathtub Forum & Blog Overflow leak? Feb 19, 2012
Shower & Bathtub Forum & Blog Leak from overflow gasket on tub drain Nov 21, 2009
Shower & Bathtub Forum & Blog Leak in Overflow May 8, 2008
Shower & Bathtub Forum & Blog Tub Leak Overflow pipe gasket Oct 22, 2005
Shower & Bathtub Forum & Blog Tub Overflow leaks to downstairs Dec 15, 2004
