Tub overflow/drain?
Discussion in 'Shower & Bathtub Forum & Blog' started by MikeVila, Nov 13, 2008.
  1. MikeVila
    MikeVila New Member
    Nov 5, 2008
    Jackson ,OH
    I have a Lasco corner whirlpool. I bought a tub overflow/drain assembly and it isn't gonna work. It is adjustable (slip) fittings but it still won't be right. I thought they were all pretty much standard?
  2. jadnashua
    What you have and what you need isn't readily apparent. They make many versions of drain/overflow assemblies, some with adjustable angle on the drain, some for deeper tubs, etc. They have to match.
  4. MikeVila
    MikeVila New Member
    Nov 5, 2008
    Jackson ,OH
    Thanks. I really have only seen a couple basic styles. Sch 40 and adjustable slip pvc. I will contact Lasco to see what they recommend. Thank you.
  5. hj
    drain
    It would help if we knew what you mean by, "it won't work right". What doesn't work right for you may be simple for us.
  6. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    'Nother reason real plumbers get the big bucks!:p:D
  7. hj
    plumbers
    That and the fact that we do not spend hours trying to make something work if it is not going to.
  8. Phil Clemence
    Phil Clemence New Member
    Jul 12, 2008
  9. MikeVila
    MikeVila New Member
    Nov 5, 2008
    Jackson ,OH
    I was going to get a schedule 40 style with pop up. It looks like you just cut the pipe to fit. With this style do you just glue the tailpiece into the trap? The one I have is just thin wall pvc (not sch.40). It is adjustable with compression style fittings. The overflow tube isn't long enough and the tailpiece won't be long enough also.
    My parents have a toe touch on there whirlpool but I believe it was the sch. 40 kit. As I mentioned would you glue the tailpiece to the trap? And yes that is why the plumbers get paid the big bucks. But I enjoy learning and doing things myself. I like to make sure I do it right and not cobbled, that has to count for something. Thx guys. What is simple for you probably isn't to alot of us. LOL. That's why your here for us. ;)
  10. jadnashua
    You just need to find a drain assembly kit designed for a tub with the depth you have. If you just pick up a generic one, it won't be long enough since most tubs aren't as deep. Some are also available to allow the overflow part to flex so if it isn't at a right angle to the main drain, it will still fit.
  11. MikeVila
    MikeVila New Member
    Nov 5, 2008
    Jackson ,OH
    I copy! I have found some that are whirlpool type specific (17"-22"). Now what about the tailpiece to P trap connection? Do you glue it? I was wondering because I will probably do plenty of dry fitting and checking things over before I start closing everything in and such. Thanks a million!!!
  12. jadnashua
    Most use a slip joint, not glued (at least that I've seen).
  13. MikeVila
    MikeVila New Member
    Nov 5, 2008
    Jackson ,OH
    I have a trap adapter for the trap. It only fits the thinwall PVC. The sch. 40 is to big. I know I just ain't got the right setup. Any ideas?
  14. Phil Clemence
    Jul 12, 2008
    I just got back to this thread , and i think i know the trap adapter you mean.
    (see pic below)
    That is designed to adapt from a 1 1/2" PVC trap up to the smaller diameter 1 1/2" Polypropylene drain/overflows.
    Hopefully you have a 1 1/2" PVC trap. In that case you won't need an adapter- you can just glue everything together- If this is not in an accesable area you definately do not want a slip joint (as with the adapter).
    The best thing would be to replace the trap if it is not PVC.
    Then the question becomes: What is the next pipe type changover from the trap? (into a main drain line or different type pipe such as old galvanized, etc.)
  15. MikeVila
    MikeVila New Member
    Nov 5, 2008
    Jackson ,OH
    Yes you are correct. I am just going to go with a PVC tailpiece and glue now. I have a PVC trap. BUT, I just found out I have to get a different one. The trap I have has a union. I guess I can't use it, have to get a solvent welded trap also. I thank you for your input.
  16. hj
    trap
    IT is not necessarily a case of you cannot use it, but more that you SHOULD NOT use it.
  17. MikeVila
    MikeVila New Member
    Nov 5, 2008
    Jackson ,OH
    Well I went ahead and got a solvent weld P trap while I was at Lowes the other day. Wife gets annoyed that I am so anal. LOL. I just like to do things the best way possible and hope to do it one time.
Similar Threads: overflow/drain
Shower & Bathtub Forum & Blog Flexible PVC vs. fixed brass bathtub overflow/drain Aug 7, 2016
