tub overflow cover
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Nikita, Aug 16, 2014.
  1. Nikita
    Nikita New Member
    Aug 12, 2014
    I have two bath+showers at home with seemingly existing identical fixtures - in master and second bedrooms. Am in the middle of replacing trim in the master and ran into a problem with installing a tub overflow cover of all things:
    Currently, there is no overflow cover in the master tub, but the hole looks like this:
    [​IMG]
    Without thinking much (a recipe for SNAFUs) I bought what I understood to be a 'standard' , however the 1/4-20 x 2" screw therein does not reach the above thread and is also nearly twice in diameter.
    For comparison purposes, I unscrewed the overflow cover in the second bathroom and the overflow looked differently: the thread is noticeably closer to the front and is larger in diameter. My replacement kit fit that second perfectly.
    So back to my master overflow (pictured above). I am unsure what kind of overflow cover thread I have and how to find a matching cover for it
    • thread it's clearly thinner than 1/4"
    • also seems like at least 2.5" screw is needed - the thread is that far back
    • the front of the thread 'face plate' feels slightly uneven - I wonder if there was more of it and the overflow cover was simply broken off at some point
    • this is a San Jose, CA townhouse, built in 1992
    I really don't want to open up the wall and replace the drain. Is there another 'typical' overflow cover screw - longer and thinner than 1/4-20 x 2"? One person suggested I drill the housing and thread it for 1/4. That could be challenging since I can feel the (plastic) drain move back if I press on the thread 'face'. Any other solution I should consider?
    Thank you,
    -nikita
  2. fullysprinklered
    fullysprinklered Well-Known Member
    Jun 15, 2014
    self-employed plumber-electrician doing residentia
    Georgia
    The other tub; does the stopper work when you turn the overflow trim piece?
  4. Terry
    Aug 17, 2004
    The plastic where the screw fit, may have broken off. They look to be the same except for that.
  5. Nikita
    Nikita New Member
    Aug 12, 2014
    The other bathtub (one with intact overflow cover) does not have a stopper. Used to have a push-pull one on top of the flange (that worked) but I took it out a few years ago once the stopper's rubber crumbled.
    Not sure what you mean by "turn the overflow trim piece"... I could temporarily put a stopper back on top of the flange - but what would that indicate?
  6. Nikita
    Nikita New Member
    Aug 12, 2014
    That sounds like the most reasonable explanation to me as well - but how do you account for the difference between thread diameters? Or are you saying the entire thread broke off and the narrow piece remaining is just the 'tail'?
    If so, do I have any options aside from cutting the wall open and replacing the entire overflow-drain pipe? (I did replace the drain flange and associated rubber gasket).
  7. fullysprinklered
    Jun 15, 2014
    Georgia
    It just reminded me of the cable operated type of w/o. You would actuate the stopper by rotating the overflow trim maybe 60 degrees. Never cared for them.
  8. Nikita
    Nikita New Member
    Aug 12, 2014
    update: going on the assumption that at least the overflow elbow (if not entire drain-waste-overflow assembly) will need to be replaced I cut out an access panel in drywall behind the bathtub. Below is a photo of overflow post and elbow. I noticed that the two are sealed with some sort of clear goo - perhaps ABS glue?
    I wonder if, instead of replacing the entire assembly, I can get away with just:
    1. cutting the overflow post a few inches beneath where it currently meets the overflow elbow
    2. attaching a new elbow to a replacement post section
    3. coupling the replacement post section with the remainder of existing post (that'll still be connected to the tee beneath)
    Good idea?
    Overflow post end elbow
    [​IMG]
  9. Nikita
    Nikita New Member
    Aug 12, 2014
    FWIW, the above worked. Thanks for all the help!
Similar Threads: overflow cover
Plumbing Forum, Professional & DIY Advice Worried About Bath Overflow Cover Plate Scratching Tub Finish Jun 24, 2013
Plumbing Forum, Professional & DIY Advice Bathtub overflow linkage stuck Mar 18, 2017
Plumbing Forum, Professional & DIY Advice Plumbing sink with no overflow. Please help Feb 23, 2017
Plumbing Forum, Professional & DIY Advice How should this humidifier overflow be plumbed? (pics) Jan 24, 2017
Plumbing Forum, Professional & DIY Advice Overflow tube under sink that seems to no longer exist Jan 17, 2017
