tub install
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by drano, Jun 25, 2011.
  1. drano
    drano New Member
    Mar 1, 2011
    nj
    I am remodeling a bathroom and installing a kohler cast iron tub...I have 1/2 plywood on top of 5/8 tongue and groove subfloor ...planning on 1/4 hardibacker on top of that which will be butting up against the tub...tub is sitting on top of 1/2 plywood my questions are... I am concerned the tub might be resting on the apron as well as the feet...should I now shim up all four feet ???so that the apron is raised off the plywood...
    thanks in advance
    gppg
  2. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    Common practice is to have the tub sitting on a ledger board, fastened to the studs and on the apron.
    John
  4. hj
    Some tubs do NOT have feet, Kohler does, but if the floor was level, and the tub is level, then it is sitting on the feet, NOT the apron, but you should also have a "ledger" board under the rim at the rear to eliminate, or minimize, separation between the tub and the tile.
Similar Threads: install
Plumbing Forum, Professional & DIY Advice Installing new shower rough-in. Remove more drywall? Feb 15, 2017
Plumbing Forum, Professional & DIY Advice Corian tub/shower surround installed over Redgard Feb 3, 2017
Plumbing Forum, Professional & DIY Advice Towel Rail Radiator Installed Sideways Jan 21, 2017
Plumbing Forum, Professional & DIY Advice Delta Tub Spout Installation Questions Jan 10, 2017
Plumbing Forum, Professional & DIY Advice Reverse Osmosis Drain Line Installation Jan 8, 2017
