tub drain thru joist layout
Discussion in 'Shower & Bathtub Forum & Blog' started by kevinrx1, Mar 21, 2013.
  1. kevinrx1
    kevinrx1 New Member
    Mar 16, 2013
    ohio
    Everyone,
    Due to windows I have to drill a 2" drain hole thru the middle of a 2x12 joist to set my tub drain. Before I do, is it okay to run the drain at a 90 degree angle ( long sweep ) on the arm for the p-trap before heading to the vertical vent/waste? It's less than 2 feet each way. See pic...
    Thanks for the advice!
  2. Terry
    Aug 17, 2004
    A 1.5" trap arm can be 42"
    A 2.0" trap arm can be 60"
    You are allowed the 90 bend.
Similar Threads: drain thru
Shower & Bathtub Forum & Blog Roman Tub/Drain...Want to Remove Monday at 10:06 AM
Shower & Bathtub Forum & Blog Delta Acrylic Bathtub Drain Sealant Feb 14, 2017
Shower & Bathtub Forum & Blog Offset PVC Solvent weld drain in Acrylic Shower base fit Feb 9, 2017
Shower & Bathtub Forum & Blog Will Fernco coupler in shower drain be prone to clogging? Feb 7, 2017
Shower & Bathtub Forum & Blog Bathtub Drain Tie-in - Help Needed! Jan 30, 2017
