Tub drain striker spring
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by lobovita, Sep 11, 2008.
  1. lobovita
    lobovita New Member
    Sep 11, 2008
    The striker spring in my tub drain assembly is broken. Believe it is a Kohler, but may be American Standard. I have checked with all local (Easton, MD) hardware and plumbing supply houses for a replacement part but with no success. And so far I have been unable to find a source on the internet. Any suggested sources??
    Rich
  2. hj
    spring
    What do you mean by "broken"? It is simply a coiled section of rod at the end of a 2 piece jointed straight section which then attaches to the trip lever on the overflow plate.
  4. lobovita
    lobovita New Member
    Sep 11, 2008
    Broken, as in the bottom half of the the coil spring is missing. This spring attaches to the bottom of a length-adjuster-link, which then is connected to the long link rod reaching up the overflow tube to the drain lever mechanism.
  5. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Why not post a picture of it?
  6. lobovita
    lobovita New Member
    Sep 11, 2008
    Broken striker spring
    Here's a picture of the bottom end of the rod.
  7. Redwood
    Dec 15, 2007
    Service Plumber
    American Standard ASBN170D
    1-866-473-6711
  8. hj
    spring
    Do you know what happened to the rest of the spring? That piece is generic so any trip waste lower link will work, Price Pfister, Delta, Moen, etc.
  9. Redwood
    Dec 15, 2007
    Service Plumber
    If its down in the drain it would be something you want to get out!
  10. chris s
    chris s New Member
    Feb 4, 2013
    lobovita,
    Were you able to find this part?
Similar Threads: drain striker
Plumbing Forum, Professional & DIY Advice HELP PLS - Drainage for Filtration and Softener System Thursday at 9:19 AM
Plumbing Forum, Professional & DIY Advice High Wall Drain, New Sink & Disposal Dilemma Wednesday at 12:50 PM
Plumbing Forum, Professional & DIY Advice New kitchen, new sink, drain too high! Tuesday at 3:54 PM
Plumbing Forum, Professional & DIY Advice Washer drain pipe Tuesday at 8:40 AM
Plumbing Forum, Professional & DIY Advice Adding Softener Drain to Main Drain Tuesday at 7:37 AM
