Tub Drain removal ?
Discussion in 'Shower & Bathtub Forum & Blog' started by fattireb, Aug 22, 2010.
  1. fattireb
    fattireb New Member
    Aug 22, 2010
    carmel, ny
    Hi All - i'm new here and have a question about removing a drain from an old tub in my basement bathroom. I want to remove it and install a new tub but can't get the drain to turn at all. I have a master extractor but it doesn't fit in that great and there is not a + on the bottom of the drain to latch into - the inside of the drain only has these 2 nubs for the extractor to grab (not working). Any advise would be great. Thanks in advance!
  2. Winslow
    Winslow Plumber
    Dec 30, 2005
    First you could try using a pair of linesmans pliers. Just insert into the drain, open them up till they are butting against the tabs, insert a big screwdriver through the handles and turn out the strainer. If that doesn't work you can cut the strainer with a reciprocating saw in three places then pry it out. If its a cast iron tub you can just hit the tub around the strainer with a sledgehammer until it breaks (wear adaquate safety clothing, ear and eye protection.
Similar Threads: Drain removal
Shower & Bathtub Forum & Blog Impossible tub drain removal!! AHHHHHHH Feb 3, 2015
Shower & Bathtub Forum & Blog Drain removal question Jul 31, 2011
Shower & Bathtub Forum & Blog Fiberglass Shower Drain Removal Dec 27, 2010
Shower & Bathtub Forum & Blog pull and turn drain removal Nov 13, 2010
Shower & Bathtub Forum & Blog Shower pan drain removal help May 26, 2010
