Tub drain removal for tub removal
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by FJK, Jan 9, 2010.
  1. FJK
    FJK New Member
    Jun 15, 2005
    Illinois
    2 questions
    Even though I did this before, I can't remember what I did.
    1st. Tub drain fitting removal. I have a cast fitting with a toe drain. The toe drain fits on a stem which has an integral cast bar across the bottom of the fitting. As a result, there are 2 180° slots in the bottom of the fitting, rather than 4 slots that a regular drain that a "dumb bell " tool would normally engage. I need something to engage those 2 slots to unscrew the drain fitting. Plier handles & an adjustable wrench are not geting the job done (too much flex).
    2nd. If the overflow & drain are disconnected from the tub only, can I manuver the tub out? Meaning, do I have to also disconnect the overflow from the drain piping? Everything is brass nuts & cast brass pipes... no leverage to brake loose the nut. I don't care to cut an access hole at this time.
    Thanks, FJK
  2. hj
    drain
    There are several tools to remove that drain fitting, but you do not have them and I do not know where you could find them in your area. If you can find a piece of flat steel the right thickness and width, you can insert that into the slots and use that to unscrew it. You could also cut the strainer out using a hacksaw blade. This would not have to be as precise as usual since you are discarding the tub and do not have to worry about damaging it.
  4. FJK
    FJK New Member
    Jun 15, 2005
    Illinois
    Well good news & some issues still to resolve. I got the tub drain fitting out by making my own tool. I took a 5" nipple of 1" iron pipe. Drilled a 1/4" perpendicular to the pipe, about 3/8" down from 1 end. I kept drilling through to the other side, so that I had two 1/4" holes 180° apart. Then I took an abrasive cut off wheel on an air die grinder & cut 2 slots from the end of the pipe to the sides of each hole, effectively getting 2 notches on the pipe 180° apart. Now the pipe had two tangs to engage the cross piece in the fitting. Using a pipe wrench on the 5" nipple, I could unscrew the fitting. It took me longer to type this than to make the tool.
    I also removed the overflow pipe to the drain elbow, after much fanagling & figuring out leverage points for the channel locks. I did this because it looks like I will have to tip the tub lengthwise, drain side down. I'll explain the reason in the "removing a cast iron tub" post.
    FJK... still on it!
Similar Threads: drain removal
Plumbing Forum, Professional & DIY Advice Oatey Caspers SBCCIES Shower Drain Removal Nov 11, 2016
Plumbing Forum, Professional & DIY Advice Cast iron drain pipe too short after flange removal - what are my options? Jan 4, 2016
Plumbing Forum, Professional & DIY Advice Removal of 50 yr old sink drain pipe Nov 7, 2015
Plumbing Forum, Professional & DIY Advice u drain trap removal cost estimate Jul 27, 2013
Plumbing Forum, Professional & DIY Advice Basement tub drain removal/change to ABS Feb 25, 2012
