Looking for suggestions on how to handle this situation. We removed the old cast iron tub that's been in a bathroom for 50 years. The attached picture is the waste pipe, house is on a slab. I can't get that nut off the waste pipe, tried spraying lots of WD-40 and let it sit but did not help enough to get a turn on it. The awkward angle does not help, I'm using some channellocks to try and turn it but they are at an angle because the nut is below the slab.
I may not be able to get the nut off the pipe, if that's the case, what's my next step?
And if I do get it off, at least the PVC drain kit leaves a slight gap going into that drain... will I need a no-hub coupling?
A brass kit was there before, any advantage to that over PVC?
