Pmaru77
I have a Kohler tub (alcove with curve) standard 60" x 30" with a curve that makes it 36" wide at center. I'm installing this in a remodel and have no access to the underneath, but only access to check for leaks. I bought the drain/overflow kit that Kohler suggested, and it was way expensive and it is all brass. The overflow has a nifty flex built into it, and I'm sure paying for that. I think the cost was $180 for the vibrant stainless brush finish. Cannot tell if it is real stainless unless I do a scratch test.
So question is, is it worth it and will it work with an install that has to finish at the tub fittings and not the p-trap drain area. Being solid brass there will not be much give if not aligned accurately I'm guessing. Also I feel more comfortable with ABS. One other thing I notices is the T fitting dose not curve downward to rid all the water, but is straight on 90 degree joint. No big deal I guess. But money wise, I do not see the value of brass. Plus I think it would be harder to work with. Can I do this connection using Home Depot parts and save some headache and money?
