tub diverter spout replacement
Discussion in 'Shower & Bathtub Forum & Blog' started by apodos, Aug 28, 2005.
  1. apodos
    apodos New Member
    Aug 28, 2005
    Where can I find a custom fitted tub diverter spout replacement?
    I broke the little plastic diverter mechanism in half; ideally, I only need to replace that little plastic piece, but I'm guessing I won't be able to do that(If you know of any way, please enlighten me). In regards to my initial question of where to find a custom fitted spout.....i've tried home depot,lowe's, etc. and they all have only the "universal" spouts. The internet doesn't seem to offer anything much more specific either. The pipe fitting in my tub where the spout fits onto is corroded and won't come off without breaking so a universal spout doesn't fit. The pipe from the wall extends about 3 1/2 inches; the pipe is 1/2 inch diameter but the fitting on the pipe is 1 1/2 inches in diameter so for the first two and a half inches that the pipe emanates from the wall the diameter is 1 1/2; the pipe becomes 1/2 inch in diameter at this point. My old spout, with the broken diverter piece has no visible brand name so I don't know where it came from but obviously it fits the pipe very well. Other than hiring a plumber to cut off the old nipple and break through my bathroom wall, any ideas?
  2. apodos
    apodos New Member
    Aug 28, 2005
    In addition, to my initial question(I've since done some research), is it possible to get an adjustable diverter tub spout which "adjusts" more than the standard 1 inch? I believe that 3 inches of "adjustment" would solve my problem.
  4. Cal
    Cal New Member
    May 10, 2005
    Northern Virginia
    Is it 1/2" copper pipe coming out of your wall? If,under all the rest of things,it's 1/2" stubbed out...you should be o.k.
    How 'bout a picture ??
  5. jimbo
    jimbo Plumber
    Anything that is 1 1/2" on the end of the stub out from the wall, is part of the old spout, and needs to be removed. That will get you back to a normal copper or IPS fitting, and you will find a standard spout to fit it.
  6. apodos
    apodos New Member
    Aug 28, 2005
    It seems that I have underlying copper pipe(looks like 1/2-3/4 inch).
    I've submitted a picture.
    Two questions: 1-How do you get the end off the underlying pipe without breaking anything(aside from getting a professional to do it)
    2-Why can't I just get a spout that fits on the pipe as is, considering my old spout fit it just fine?[​IMG]
  7. apodos
    apodos New Member
    Aug 28, 2005
    Sorry, not only can't I fix my tub, I can't figure out how to insert a photo in my message
  8. jimbo
    jimbo Plumber
    One fairly easy way is to post the pic. at www.photobucket.com This is a free service, and although I am less than adept at computer stuff, I usually can manage to upload a pic. there when I need to and then it is postable on websites. Try it!
Similar Threads: diverter spout
Shower & Bathtub Forum & Blog Upgrade Manufactured Home 2 Handle Valve with Bath Shower spout and diverter Jan 11, 2017
Shower & Bathtub Forum & Blog Is this Grohe leaky tub spout diverter repairable?? Jan 2, 2017
Shower & Bathtub Forum & Blog Slip-on tub spout w/ diverter recommendation? Sep 20, 2016
Shower & Bathtub Forum & Blog Water comes out from shower diverter spout May 23, 2016
Shower & Bathtub Forum & Blog How does shower line drain through tub spout when valve is off and diverter is set to tub? Apr 3, 2016
