Tub Bedding
Discussion in 'Shower & Bathtub Forum & Blog' started by fowlermi, Dec 30, 2007.
  1. fowlermi
    fowlermi New Member
    Dec 30, 2007
    I saw on one posting where you said bedding just needs to be some piles that will smoosh down when the tub is installed. I am installing an American Standard whirlpool tub, model 2425L/V-LHO which is recommending mortar bedding for the entire bottom of the tub. It is being installed on a concrete foundation of a 13 yr old house. I have 3 questions.
    1. What is the best way to go about ensuring the maximum amount of bedding support for the complete bottom of the tub?
    2. What is going to keep the mortar from cracking and crumbling away when there is 500-600 lbs or more of water and body in the tub?
    2. The installation instructions are a little vague on voiding the warranty if a certain size access door is not provided for the pump end of the tub. My problem is because I am replacing an existing tub, the pump end is on an outside wall making a pump access door impratical. The tub itself has an access panel on it. Do you think American Standard will honor the warranty?
  2. jimbo
    jimbo Plumber
    San Diego, CA
    A warranty would be of little value if a service man could not access the pump for repair.
  4. construct30
    construct30 New Member
    Jun 16, 2007
    NorthWest PA
    You have to get enough mortar, but not too much. It has to have a place to go as you set the tub down level. Getting the tub level is the trick. If you go too low, you have to pick the tub up and add more mortar. I've seen tubs with full mortar beds that the bottom still flexed because they pushed the tub down too far pulled it back up and secured it. A tub with a full lip the entire way around, drop in, is easier.
    You need a good access panel. I've seen drop in tubs that had to be lifted for repairs, very expensive.
Similar Threads: Bedding
Shower & Bathtub Forum & Blog Bathtub Mortar Bedding May 5, 2015
Shower & Bathtub Forum & Blog A "quick setting thinset mortar" ok for bedding acrylic tub? May 25, 2011
Shower & Bathtub Forum & Blog Cast Iron Tub, Mortar bedding required? Jan 9, 2011
Shower & Bathtub Forum & Blog Bedding Material Feb 19, 2006
Shower & Bathtub Forum & Blog BathTub-Bedding !! Oct 8, 2005
